Aftermarket rear locker options??
Discussion in '3rd Gen Tundras (2022+)' started by johnye75, May 30, 2023.
  1. May 30, 2023 at 9:07 AM
    johnye75
    johnye75 [OP] New Member
    emo
    2022 tundra SR
    n/a
    Do any exist for the non trd models ??
  2. May 30, 2023 at 10:40 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I mean, couldn’t you just retrofit the factory locker?
  3. May 30, 2023 at 12:27 PM
    alaska_bou
    alaska_bou New Member
    I would advise you to make sure you actually need a rear locker before adding one. My last truck had one, and in the seven years I owned it I used it only once (and it made no difference in that situation). My driving needs just don't warrant a rear locker (backcountry roads, two-tracks, mild off-roading).
  4. May 30, 2023 at 3:06 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Mine used to lock at the most inopportune times in parking lots. It was… interesting. It was, however, VERY useful in some situations. They weren’t really anything popping it into 4wd wouldn’t have remedied.
  5. May 30, 2023 at 3:49 PM
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    Doing a factory locker on a Tacoma is a huge hassle (wiring). Much easier with aftermarket and the aftermarket lockers for Tacomas are superior than the OEM
    ramnj and eddiefromcali like this.
  6. May 30, 2023 at 3:52 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Much rather have an aftermarket locker that doesn't disengage after Xmph.
  7. May 31, 2023 at 4:37 PM
    johnye75
    emo
    2022 tundra SR
    n/a
    Yes, aftermarket option is what I was hoping for. I can't imagine it won't be available at some point, but I guess 1.5 yr later, still none!?
  8. May 31, 2023 at 4:38 PM
    johnye75
    emo
    2022 tundra SR
    n/a
    Are you saying that you have added 360 degree cameras and sensors? You mean aftermarket or you used oem ? What else have you done to your SR, I have one too :)
