Aftermarket Headunit Microphone Location
Discussion in 'Audio & Video' started by TXTundraFan, Oct 31, 2020.
  1. Oct 31, 2020 at 6:50 PM
    TXTundraFan
    TXTundraFan [OP] New Member
  2. Nov 1, 2020 at 8:31 AM
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    It's not hard to fish the wire. I just ran it using the opening under the dash on the driver's side. I just tucked it behind trim pieces and did not have to take anything apart.
  3. Nov 1, 2020 at 8:41 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I put mine right on top of the steering column.
    BrandonL812 likes this.
  4. Nov 1, 2020 at 9:08 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Above rear view mirror at the top of the windshield. Tucked wire inside headliner.
  5. Nov 1, 2020 at 9:52 AM
    TXTundraFan
    I found a good spot. I have it sticking out of the front of the top center speaker grille. I don't have a center speaker so the hole was easy to route the wiring up through.
  6. Nov 1, 2020 at 2:33 PM
    Buckeye1977
    Buckeye1977 New Member
    I put mine on the steering column as well no complaints.
  7. Nov 2, 2020 at 1:54 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    I installed mine in the upper right hand corner of the instrument cluster trim bezel. I simply drilled a comparable hole, and installed a rubber grommet. Looks great and works even better!
