AFTERMARKET GRILLE ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2010bigdog, Mar 8, 2020.
  1. Mar 8, 2020 at 11:29 AM
    2010bigdog
    2010bigdog [OP] New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Im looking to replace my grille on my 2018 tundra and it says it will only fit 2014-2017 and was wondering is that only because of the sensor in the front ?
    Thanks
  2. Mar 8, 2020 at 1:34 PM
    Cthulhu
    Yes, the TSS sensor started in 2018, and as far as I know, there are no after market grills supporting the TSS sensor yet. You have two options, buy a Toyota OEM grill that supports the TSS sensor (grill needs to be 2018 or later), or buy a TSS sensor relocation bracket, and then you can get any grill you want. AJT Designs makes a really affordable one. I have it and it works great.
    TWJLee likes this.
  3. Mar 8, 2020 at 1:38 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Me too
  4. Mar 8, 2020 at 1:44 PM
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    DB Customz is an aftermarket grille that supports the TSS sensor. Their own bracket is built into the grille.
  5. Mar 8, 2020 at 1:56 PM
    Cthulhu
    I stand corrected...
  6. Mar 8, 2020 at 3:07 PM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    That DB one looks real nice... With color matching available- best option I've seen imo.
    Ckatz53 likes this.
  7. Mar 8, 2020 at 3:10 PM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    You have any issues with the engine running hotter, since it seems like that grille would restrict some airflow compared to stock.
  8. Mar 8, 2020 at 3:10 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    It looks like the truck is smiling with a mouth full of chiclets for teeth. I’ll take oem options any day over this monstrosity.
  9. Mar 8, 2020 at 3:20 PM
    Ckatz53
    Ckatz53 Newish
    MD
    Stock gauges show it running the same temp.
    Leave my chiclet grille alone dog. Big chiclet guy here.
    1UP, Sumo91, The Californian and 5 others like this.
  10. Mar 8, 2020 at 3:41 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    I have the t-rex aftermarket grill, that is 18+ TSS compatible. It's a regular billet grill with a spot to transfer the whole emblem assembly onto the new grill.
    I cannot recommend this grill, as I had to completely take apart the emblem and place it into the grill. I purchased it when they first started manufacturing it, so unless the design has changed, I would stay away from this one. Everything works perfectly functionality wise with the TSS, however the emblem and sensor will never come off this grill...EVER!
    Also, the billet grill is bolted to the truck and the grill shell is mounted separately from the grill itself if that makes any sense. Just an FYI
    Edit: also... if you decide on an aftermarket grill, make sure to get the TSS recall update done prior!! As you will not be able to get it with an aftermarket grill, no exceptions
    prevent and Ckatz53 like this.
  11. Mar 8, 2020 at 4:11 PM
    Aukum
    Aukum New Member
    2019 Cavalry Blue Tundra
    trying to eliminate chrome
    Hey I am new to this forum so not even sure if I am doing this right. dbcustomz.com has grilles that work with our TSS sensors. I just placed my order today. So excited!
    Ckatz53 likes this.
  12. Mar 9, 2020 at 4:36 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    the one I want is from RC. Where and how much are the relocation brackets?
  13. Mar 9, 2020 at 4:50 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    B60E00A3-2A02-4EDC-B8E9-38CA84153159.jpg this one
  14. Mar 9, 2020 at 4:51 PM
    YotaMan
    Colorado Springs
    2021 Platinum
    I doubt the relocation brackets will work with that grill
  15. Mar 10, 2020 at 3:36 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Thanks for the info so far
  16. Mar 24, 2020 at 10:52 AM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    34DA642B-062B-4C6E-9138-AE43B3C6DE01.jpg How about this one ?
  17. Mar 24, 2020 at 11:11 AM
    SoCalRandy
    SoCalRandy New Member
    Randy
    San Diego, California
    2020 MGM Limited Crewmax 4x4
    I don’t believe that grille will work for ‘18+ Tundra’s with the TSS sensor.
  18. Mar 24, 2020 at 3:11 PM
    Cthulhu
    That one looks like it will work, coupled with an AJT relocation bracket for the TSS sensor.
    texasrho83 likes this.
  19. Mar 24, 2020 at 4:21 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Thanks for your feedback. You don't think the first one will though ?
  20. Mar 24, 2020 at 5:01 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Trex makes grills that accommodate TSS.
  21. Mar 24, 2020 at 5:03 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    website ?
  22. Mar 24, 2020 at 5:04 PM
    14burrito
    2014 SR5 CM 4x4 5.7
  23. Mar 24, 2020 at 5:04 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
  24. Mar 24, 2020 at 5:07 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Exaggerated a little on all sorts lol, thought they made more than they did. In any case, it's another option.
  25. Mar 24, 2020 at 5:09 PM
    Cthulhu
    With the LED bar mount built-in? Probably not, unless you were to mount the bracket further up on the center support behind the grill, but that could possibly throw off the TSS geometries to where the TSS system might not work. Of those two, I would definitely try the one without the LED bar.
    The Trexbillet ones are nice too...just pricier.
  26. Mar 24, 2020 at 6:47 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Yeah that are pricey! Think maybe I will try one of the RC ones and hope it works lol. I’ll look a little bit more then decide though
  27. May 7, 2020 at 10:38 PM
    R3MY
    R3MY New Member
    2020 Tundra Sport
    I have a 2020 Tundra Sport, I going to try the RC Grille with the LED lights with the Jomax adapters. I think that those may work better for this setup opposed to the AJT. Anyone here tried the Jomax?
  28. May 8, 2020 at 3:13 PM
    ryanryan34
    ryanryan34 "Its almost done"
    Ryan
    Olympia WA
    2016 Supercharged Overland Build
    Supercharger, Carven Cat-Back, Rough Country Heavy Duty Front and Rear Bumpers with grill insert, , BDS 3" Suspension Lift, 18x9 XD 820s, Kenda Klever 33x12.5, AJT Designs interior items, De-badged, Tuffskins custom door sills, RCI Skid plates. Victory 4x4 Bed rack and Stiffeners. Roofnest Condor XL RTT
    Here is my 2016 with the RC mesh grille with the matching Heavy Duty bumper
  29. Aug 14, 2020 at 4:56 AM
    Ry24000
    Ry24000 New Member
    Ryan
    Carson, WA
    2019 Tundra SR5 TRD offroad Quicksand
    Debadge, ARE z series top, Ironman Foam cell pro 3" lift, SPC UCA's, ICON vector 5 & Toyo ATIII 285 75R 17, Warn 9.5XP mounted in a Victory Blitz bumper. GTR 1000LM+XTR LP Reverse Light System
    Any grills that don't have company logo's on them?
  30. Jan 8, 2022 at 3:39 PM
    The X on the Trex grills are removable.
