Aftermarket fog lights aren’t working. 2005 tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Chris V, Jun 22, 2019.
  1. Jun 22, 2019 at 3:39 AM
    Chris V
    Chris V [OP] New Member
    Christopher
    2005 Tundra SR5 DBL CAB 4.7L RWD
    Hello everyone. I new to this forum and I’m hoping that someone here can help me. Here the issue.
    FOG LIGHTS NOT WORKING! So frustrated!
    I have a 2005 Toyota Tundra SR5 DBL CAB 2WD 4.7L. I installed aftermarket fog lights, which I used the factory plugs for the fog lights, I replaced the stalk with one that has the fog light switch, fuse was already installed in its place, and install the new relay. Now my problem is the lights aren’t working. I don’t hear the click on the relay when I turn on the fog light switch. Any help or troubleshooting direction would be Greatly appreciated!!
  2. Jun 22, 2019 at 4:20 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    Were they grounded?
    Break out the multi meter and start testing.
    You said you used the factory plugs. I would start there.
  3. Jun 22, 2019 at 4:45 AM
    niedejb
    niedejb New Member
    Sumter, SC
    '17 Platinum
    Unless you have done the "anytime fog light mod" you have to have the fog light switch on AND the low beams.
  4. Jun 22, 2019 at 7:10 AM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Welcome from Florida.
    I have a similar issue, when I turn on the fogs I get high beams. Did everything like you did, I'm suspecting the wires in the switch plug may need to be moved. I haven't had time to mess with it yet.
    Chris V[OP] likes this.
  5. Jun 23, 2019 at 2:10 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Sounds like you may have possibly reversed two wires.
  6. Jun 25, 2019 at 4:48 AM
    Chris V
    Christopher
    @Gotyour6 So there is no power to the factory plugins at the fog lights. Not sure where the ground is one the factory wiring but I'm looking!
  7. Jun 25, 2019 at 4:52 AM
    Chris V
    Christopher
    @Hooptytrix The high beam and low beam work as they should at this moment. Like I said the fog lights have no power to them. The relay doesn't click when the fog light switch is turned on.
    @because_v8 What wires are you suggesting to reverse? On the stalk of the fog light switch?
  8. Jun 25, 2019 at 5:00 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    You need to look for the schematics for your wiring and find out where or what they are connected to
    There may be a lead wire that would be mounted on a panel if the fog lights were factory but they never put a switch in because they never put fog lights in.
    Under your dash there may be wires that are looking for a switch.
  9. Jun 25, 2019 at 5:18 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Are your low beams on?
    Chris V[QUOTED][OP] likes this.
  10. Jun 25, 2019 at 5:21 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    I'm merely suggesting you may have wired it wrong. Pics would really help.
  11. Jun 25, 2019 at 5:36 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Here's the diagrams for the fog wiring with and without DRL.
  12. Jun 25, 2019 at 5:49 AM
    Chris V
    Christopher
    @because_v8 yes they are on when I switch them on. And the high beams work as they should. I didn't't actually wire anything. Literally plugged everything in its place. Plugged in the fog lights into the existing harness, placed the relay into the designated area under the interior fuse box, and installed a new light stalk with fog light switch.
    @Festerw thanks for the diagram!!
    @Gotyour6 Thanks! with the diagram and your suggestion, looks like I have a good direction to start from!!
  13. Jan 23, 2021 at 5:27 AM
    TrooperCole02
    TrooperCole02 New Member
    Hey guys I have a similar issue, I own a 2005 Toyota Tundra SR5 and recently installed fog lights and the fog light switch from another tundra. Used the factory plug in and all that it does is turn on the high beams with the new switch. Low beams and the fog lights don’t work. Has anyone figured out how to make it all work?
