Aftermarket Bumper Twist
Discussion in '2nd Gen Tundras (2007-2013)' started by Mattlikesbikes, Sep 27, 2018.
  1. Sep 27, 2018 at 9:53 AM
    Mattlikesbikes
    Mattlikesbikes [OP] New Member
    I got a great deal on a lightly used ICI Magnum PR for my 2013. It had been mounted, though it came from a closing bumpershop with a full new box of the mounting hardware (two towers from bumper to frame, bolts, etc).
    Everything mounted up fine, but when I got to the last step of getting it level and squared up I ran into trouble. It is almost as if the bumper is twisted a touch, like when you weld up a frame too fast and don't account for heat twist when it cools.
    If I pull it up perfectly level on the right side, 1/4" under the headlight trim and fender, the other side is way off. 1/2-2/3" under the headlight trim near the grill and touching the bottom of the fender at the wheel well at the other.
    Is this common (twist/warp) with these big ass bumpers? Other than throwing washers in as spacers to try and get it twisting correctly, any other suggestions? Or just suck it up and live with it, I got a $1500 bumper for $400.
  2. Sep 27, 2018 at 10:58 PM
    Brad90
    Brad90 New Member
    Brad
    2013 Tundra Crewmax Rock Warrior
    aFe Power Magnum Force Stage 2 SI PRO-DRY S intake, aFe Mach Force XP exhaust, 3 inch leveling kit, DVB front bumper, tri-fold tonneau cover.
    I have the exact same problem with my DVB bumper. It bugs me because of the gap difference.
    Black Wolf likes this.
  3. Sep 28, 2018 at 7:52 AM
    Mattlikesbikes
    My problem is the gap is the opposite on the other side, nearly touching at the grill and 3/4" low at the wheel well. So twisted.
  4. Sep 29, 2018 at 6:44 AM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    If you can fix it with washers as spacers or oval the holes in the mounting bracket to allow you to pull the front up, that's what I would do.
    I have made bumpers for my other trucks and it is hard to get everything even. The bumper may be flat but the frame and holes could be off.
  5. Oct 4, 2018 at 5:50 AM
    Rob371
    Rob371 New Member
    Rob
    Charlevoix, Michigan
    2007 Tundra Crewmax
    Steel bumpers front and rear,1.4" bilstien, KatSkinz Leather, rear airbags, halos.
    Same bumper but I have the RT. I think they call the one you have "prerunner". I did front and rear. They also make a skid plate. I think it was maybe 75 or 100 bucks for the skid. I didn't have any twisting issues. I'd probably just shim it and adjust it best you can. It might bug you but likely nobody else is going to notice unless you point it out. Mines been on for two years. Powder coat is failing all over the place but I'm also in a northern climate. The coating starts failing at the edges. ICI should have rounded the sharp edges prior to powder coat to prevent this.
    They hooked me up on price. I bought everything direct from ICI at the same time for something like 1800.00
    You might swing into your favorite body shop. Body guys usually have little tricks to get things aligned better. Might be worth an hour or two of labor to let them try.
  6. Oct 6, 2018 at 5:03 AM
    Rob371
    Rob371 New Member
    Rob
    2007 Tundra Crewmax
    Just looking at the photo again. You could probably get some out the old school way of hooking chains to a tree or something solid and use the truck to pull it out. Gonna take some head scratching getting the right pull. Floor jack, chain fall, some lumber, and some delicate tweaking here and there. A monster sized dead blow would help. All that could easily go bad for you though.
    I think I'd just go to a body shop. They can anchor it to the floor if necessary. For what you have invested you could spend another couple hundred bucks and still a great deal.
  7. Oct 6, 2018 at 5:10 AM
    Same here with my DV8 although I bitched and got $150 refunded. Sometimes the jigs get set up wrong.
    Brad90[QUOTED] likes this.
  8. Oct 6, 2018 at 7:39 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Live with it and if people ask your story is "I ran a prius off the road".
    Stormtrooper81 and Brad90 like this.
  9. Oct 7, 2018 at 6:01 AM
    Rob371
    Rob371 New Member
    Rob
    2007 Tundra Crewmax
    You might even call ICI located in Arizona. I dealt with them direct. Rafeal was my contact. A couple of their engineers owned gen2 Tundras at the time I did mine. They might have some suggestions for you.
    Rafael Riveros / Regional Sales ManagerMain: 623-486-2300 ext. 415 / Direct: 480-389-0989 Rafael@icionline.com
    Innovative Creations Inc.Office: 1-800-626-8746/ Fax: 623-486-3886 8960 W. Larkspur Drive Ste. #107 Peoria, AZ 85381
