Aftermarket bumper problem
Discussion in '2.5 Gen Tundras (2014-2021)' started by hinow41, Sep 3, 2020.
How to fix
  1. Try to dent body work so its out of the way
    0 vote(s)
    0.0%
  2. Remove bumper and grind down area where its rubbing
    0 vote(s)
    0.0%
  3. Other ?
    1 vote(s)
    100.0%
  1. Sep 3, 2020 at 9:09 AM
    hinow41
    hinow41 [OP] New Member
    Rob
    I recently installed the DV8 bumper on my truck and I noticed some noises coming from the front when driving. I thought it was suspension at first with the added weight of the bumper and winch. Turns out the noise is coming from where the bumper mounts is rubbing against a part of the body work. See photo. When the body flexes the bumper rubs against that part. Any suggestions on a fix with out removing the whole bumper?
  2. Sep 3, 2020 at 9:52 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    That looks like the lower tie bar on the radiator support. I would just take some channel locks and bend it back, won't effect anything. Also I would check the other side.
    Or shim the bumper forward?
  3. Sep 3, 2020 at 10:11 AM
    timsp8
    NY
    Is the bumper adjustable? I just did an aftermarket bumper and the way the mount was designed, I could move it forward/back or up/down. Can you move it out any?
