After the Lift Kit…What to do with the Spare Tire?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by TruPatriot, Oct 17, 2021.
  1. Oct 17, 2021 at 10:53 AM
    TruPatriot
    TruPatriot [OP] New Member
    Lee
    Northeast Texas
    2020 TRD Pro MGM Mall Crawler & Trail Riding Queen
    I had the Westcott Lift Kit installed along with 295/70/18 Toyo AT3’s and I couldn’t be more pleased. Now I’m scratching my head on what to do with the spare. My plan is to sell the stock Michelins along with the new spare tire. Will a 295/70/18 fit in that same spot under the truck? Should I get a used 285/70/18 that may fit? Anyone that has dealt with this issue, I’m all ears!
  2. Oct 17, 2021 at 10:56 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    295/70R18 will fit, you just might have to bend the guides or remove them completely. But many have fit 35s under there pretty easily.
    DW707 and toyofan87 like this.
  3. Oct 17, 2021 at 11:07 AM
    biebs96
    PA
    If you have stock rear shackles. You’ll be able to fit a 35” no problem. Just remove the metal guides with a cut off wheel.
    Here you can see all the room with a 35” spare and an exhaust resonator installed.
    Here you can the space between the factory springs and the 35” spare.
    hopefully all this helps you OP.
  4. Oct 17, 2021 at 11:57 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Any new pics of said lift? Thx
  5. Oct 17, 2021 at 12:02 PM
    TruPatriot
    Lee
    Northeast Texas
    That’s good to know…thanks!
  6. Oct 17, 2021 at 12:03 PM
    TruPatriot
    Lee
    Northeast Texas
    Pics always helps…thank you!
    biebs96[QUOTED] likes this.
  7. Oct 17, 2021 at 12:05 PM
    TruPatriot
    Lee
    Northeast Texas
    Here you go!
    Markh314, Sundog, Winning8 and 2 others like this.
  8. Oct 19, 2021 at 7:21 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Question just like these small spares that are added to other cars. Between the stock size and 285 or 295 if you get a flat is it really going to hurt to drive the truck home?
  9. Oct 19, 2021 at 7:25 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    As long as you aren’t using 4wd, the stock spare will be fine to get you home, or at least to a tire shop. But a matching spare is obviously ideal.
  10. Oct 19, 2021 at 7:26 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Depends on far home is. For me, I have the Powertrax Grip Pro differential so I would not want to drive too far with mismatched sizes.
  11. Oct 19, 2021 at 7:30 AM
    RusPro21
    Don
    Pa.
    I agree with both. Just curious because I have 285’s on my Pro and I’m not changing the spare size. As long as it gets you home that’s the way I look at it. Or even if your traveling you should be able to make it to a tire place.
  12. Oct 19, 2021 at 8:08 AM
    crewmaxlmt
    scott
    I wouldn't worry about if you have the factory diffs. Just a little annoying to drive.
  13. Oct 19, 2021 at 9:39 AM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    Is the spare tire wheel a +60 offset? Curious if just putting a bigger tire would work in the event you needed to use it for a front tire…I guess you could always switch a rear to the front and run the spare on the rear if offset is a clearance issue at the front
  14. Oct 19, 2021 at 9:57 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    I think you would want to run the smaller/different wheel size in the front (not in 4x4) to avoid messing up the rear diff.
  15. Oct 19, 2021 at 11:09 AM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    that seems to makes sense when running a smaller diameter tire height…but this makes the spare offset even more important if I want to run a full size (matched height) spare. Im running 35’s on +10 offset wheels which provides plenty of clearance with stock UCA…trying to determine if I can just get a 35” tire for the factory spare, but if it is a +60 offset, then I potentially run into UCA clearance at the front
  16. Oct 19, 2021 at 11:16 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yeah if you're running a matching spare, you'll probably need to get a matching wheel. Most tire shops won't mount a 12.5 wide on the OEM wheels, let alone the spare wheel. If you didn't want to replace the wheel itself, you could grab a 285/75R18 assuming you have an 18" spare and be pretty close on the diameter.
  17. Oct 19, 2021 at 11:30 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    35x12.5 Nitto RG's on a matching 701 with CB Shackles...tight but do-able
    note that the first pic is with OE shackles before lift.
    exhaust clearance..
    Hope that helps.
    Ron_Pro, biebs96 and boostedtrdpro like this.
  18. Oct 19, 2021 at 11:43 AM
    crewmaxlmt
    scott
    Mine looks about the same with a 285/75-18 and Toytech shackles. You will need to take your time guiding it up there.
  19. Oct 19, 2021 at 11:56 AM
    scpete24
    scpete24 Duuuuuuude
    Orange County, CA
    I see what you're saying on the offset, I was just thinking of the diff. I'm going to 35's in a couple weeks and plan on putting one of my old 295/70/18 on the spare wheel, but now I might just get a matching spare wheel to match everything close as I can other than the tire size...
    1P7R9O4[QUOTED] likes this.
  20. Oct 19, 2021 at 11:59 AM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    This is exactly what I have going on too clearance-wise. Coachbuilder +3 and 35x12.50 Toyo's. How long have you had yours like this and has there been any contact that you can tell? I'm worried about at full droop. I'm planning on taking some GoPro video of it this weekend with some light offroading to see if it makes contact. Side note, those of us with the TRD Pro exhaust have to fight that also raising the tire into and out of its nest up there.
    21B81C5D-2D46-4A22-B549-B7B811286D86.jpg 7E306F74-A9A8-455A-AD10-0CEFF32B6858.jpg
  21. Oct 19, 2021 at 12:55 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Photos at soft droop (nominal +4-4.25"). Don't mind the Arizona Pinstripes and the dirt...truck does get driven 2-3 times/month in the Arizona countryside with 5 wheel rotations every 2.5k mi.
    Shackle bolt head does make contact with the spare (mind you RG is closer to 35 dia. than most). Dropping the spare did not increase articulation or droop and for those curious what the bolt head of the CB shackles +2 does to the spare..
    Drivers Side (lowered by spare hoist for better line of sight)
    Passenger Side (lowered by spare hoist for better line of sight)
    Hope this helps someone...
    scpete24 and boostedtrdpro like this.
  22. Oct 27, 2021 at 1:59 PM
    Gman8P0W1
    Gman8P0W1 New Member
    Utah
    21 Lunar Pro
    ADD Venom w/Rigid 30” AT Overland Summit KMC: 315/70/17 KO2
    I drilled out the frame rivets it took about 20 mins per a side for the guides
  23. Oct 27, 2021 at 2:55 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    that's what she said
  24. Nov 18, 2021 at 2:25 PM
    Sonicbluerider
    Sonicbluerider New Member
    Dennis
    2019 Tundra
    So I'm adding methods with a 25 offset an bough new lug nuts. Will I need to keep a set of old lug nuts if I need to put my stock spar tire/ rim on??
  25. Nov 18, 2021 at 6:50 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    yes.
  26. Dec 14, 2021 at 5:06 AM
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    How are people storing 37 spares? Other than just tossing in the bed
    DW707 likes this.
