After market tailgate lock
Discussion in '2.5 Gen Tundras (2014-2021)' started by vader7071, Dec 31, 2018.
  1. Dec 31, 2018 at 6:13 AM
    vader7071
    vader7071 [OP] New Member
    Dothan, AL
    2018 SR5
    Has anyone added this to their tundra?
    https://www.amazon.com/Pop-Lock-PL8535-Tailgate-Toyota/dp/B00LST3022
    I like the idea, and watching the install videos looks easy, I just don't like the "expose the door lock wires and tap into them". I would much rather have something that looks more factory. Preferably a harness to tap the wires with, or at least know what open pins in an existing harness I can use to trigger the lock.
  2. Dec 31, 2018 at 6:28 AM
    mgxsequioa
    mgxsequioa New Member
    Watt maker and HappyGilmore like this.
  3. Dec 31, 2018 at 6:50 AM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Make sure you research the wire color and routing for your year truck. The included instructions aren't correct alot of the time. I found 2018 instructions on YouTube and it worked great.
    OR18TRD, mgxsequioa and Watt maker like this.
  4. Dec 31, 2018 at 7:48 AM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    One of my favorite mods. Wish i would have done it right when I got the truck. 80 is the best price you're going to get on Amazon. It jumps between 80 an 104 quite a bit lately, so jump on that 80 price. Camelcamelcamel will also track price for you on Amazon.
    HappyGilmore likes this.
  5. Dec 31, 2018 at 8:26 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You can buy the universal kit for around $10 and it serves the same purpose and works well.
    chugs and NewImprovedRon like this.
  6. Dec 31, 2018 at 8:28 AM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    I'll get ripped for it, but I sure do like the bracket with that kit. Makes it super easy and is very stout. By all means I like fabbing stuff (just hooked up Ridgid fogs with the OEM trim), but int his case, I just wanted to install and be done. The kit served this purpose perfextly
    Smoofers likes this.
  7. Dec 31, 2018 at 8:49 AM
    HappyGilmore
    Trent
    Lakewood CA
    Agree with you on that one. Its a nice CNC bent stainless bracket that you know won't come out of alignment. And the actuator harness had nice compact vulcanized insulation instead of loose bulky split loom. At 80 bucks I think it's worth it.
  8. Dec 31, 2018 at 8:56 AM
    Whocares
    Whocares Member
    Do it. Install is easy and the practicality of it is priceless.
    yosh2000 likes this.
  9. May 17, 2019 at 1:09 AM
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    2013 Tundra SR5 Crewmax 4x4
    Bud Built skid plates, Fox TRD Pro suspension, Nitto terra grapplers
    This place has a plug n play adapter. They also have a harness to relocate your rear sliding window switch.
    https://accessorides.com/products/p...ndra-2011-2017?rq=yr_2013~mk_toyota~md_tundra
  10. May 17, 2019 at 12:43 PM
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    has anyone tried the plug and play adapter? seems like a good idea...…….
  11. May 17, 2019 at 12:47 PM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    Adapter isn't worth $40. It's just 2 wires. Plenty of YouTube videos that show which bottom 2 wires to tap into using a simple scotch lock. No issues with my pop and lock at all and has been a great addition being able to get i to my tailgate without having to shut off my truck and take the keys out to unlock it
    chugs likes this.
  12. May 17, 2019 at 6:30 PM
    J.A.T.O.
    J.A.T.O. New Member
    Hawaii
    I agree $40 is pricey but I’m sure it’s peace of mind for some folks.
