After market fog light suggestions
Discussion in '2nd Gen Tundras (2007-2013)' started by Rod311, Feb 27, 2023.
  1. Feb 27, 2023 at 8:34 AM
    Rod311
    Rod311 [OP] New Member
    Rod
    2012 Tundra RW -DC
    New Head unit with Nav, Airbags and camper cap (F250)
    Has anybody installed fog lights into a truck that doesn't have them already? Is there a plug and play kit I can buy?
  2. Feb 27, 2023 at 8:37 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    You may already have the wiring from the factory. I would check that first. If you do I think it would be pretty simple. You might have to get a fog light switch or change the stalk for the headlights to one with a fog light switch. Not sure what the second gen is like exactly in the inside but thats just a general path forward.
  3. Feb 27, 2023 at 8:45 AM
    When I had my 2010, Toyota had a kit with harness and a dash mounted switch so that you didn't have to mess with the stalk at all.
    MadMaxCanon likes this.
  4. Feb 27, 2023 at 8:51 AM
    Rod311
    Rod
    2012 Tundra RW -DC
    That's what I was thinking. Do they install wiring with every tundra even if it doesn't have the option. This is my stalk. Can you tell whether it has that from the pic?
  5. Feb 27, 2023 at 9:23 AM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    Does not.
    We are in the same boat.
    I bought Morimoto XB LED fog lights for Tundra application. Most everyone has said the trucks are wired. So you buy a relay, the buckets for the fogs, some aftermarket fogs, and either pull the wheel and install the new switch w fog switch or buy an ebay switch and custom wire it. I'm doing the later as I want full control of them turning them on when the running lights are on.
    52125-0C020 Lamp Housing $60.90
    52126-0C020 Lamp Housing $60.90
    90080-87026 Multi Purpose Relay $18.99
    Amber switch for Tundra
    https://www.ebay.com/itm/331762454130
    Let me know if you want the OEM switch PN, it's buried in an email somewhere....
