After market back up camera
Discussion in '2nd Gen Tundras (2007-2013)' started by Rod311, Feb 27, 2023.
  1. Feb 27, 2023 at 8:38 AM
    Rod311
    Rod311 [OP] New Member
    Rod
    2012 Tundra RW -DC
    New Head unit with Nav, Airbags and camper cap (F250)
    I have a back up camera installed in Mt Tundra but it's not very great for clarity and depth. I also would like to be able to see my ball for hooking up trailers. Anybody have an aftermarket setup that would be better?
  2. Feb 27, 2023 at 10:33 AM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    Listed in my build thread
    I went with an OEM style backup camera that is mounted in the tailgate handle assembly. https://www.amazon.com/dp/B07WR9C3M4
    It isn't the highest resolution, but gets the job done. You can see part of my bumper in the picture so no problem seeing a tow ball.
    PermaFrostTRD likes this.
  3. Feb 27, 2023 at 2:39 PM
    Rod311
    Rod
    2012 Tundra RW -DC
    Yeah. That's it! Thanks
  4. Mar 14, 2023 at 6:19 PM
    rmeyer7
    rmeyer7 New Member
    Roy
    2008 Double Cab 5.7L
    Has anyone else installed an aftermarket backup camera that you really like? Most of the ones I'm seeing seem to be just OK in terms of picture quality, I'd like to find one that's better, especially in the dark. If you've found a good option you recommend I'd appreciate any info.
    This would be for an '08 base model with no factory backup camera and a 6' 6" bed. I've also heard some of these units have short wires and wouldn't be recommended for anything longer than the 5' 6" bed so that would be another consideration.
  5. Mar 15, 2023 at 3:54 AM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    I did this research and ended up with the same tailgate handle camera cited above: https://www.amazon.com/dp/B07WR9C3M4
    The positioning (looking down) is the most important factor. If you use any other camera it'll be attached to the plate, looking out, and that makes it difficult to judge depth.
    But the IQ is fine. Many advertise higher quality cameras but this seems about the same as those.
    If it's dark your best bet is to add backup lights to the bumper (which I plan to do at some point).
    rmeyer7[QUOTED] likes this.
  6. Mar 15, 2023 at 10:08 AM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    The one I linked to above has a so-so image quality and I would like it to be better, but the main thing is can I see objects/people I don't want to run over. No, I am not seeing them in HD, but quite functional. For the length of wire/wire loom, that camera had plenty of cable for my 2008 double cab (6.5' bed, no factory camera) to route it out the tailgate and then follow the stock wiring loom along the passenger side. I brought it up into the passenger area of the cab and to the head unit.
  7. Mar 15, 2023 at 11:02 AM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2025 RAM 3500 6.7L Cummins
    As a workaround for seeing the trailer hitch I'll sometimes use this hack. Keeps the tailgate clear and gives you a good overhead view when hooking up.
  8. Mar 15, 2023 at 11:10 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    After I installed the Pioneer HU, I also couldn't help but notice the horrible quality of the OEM rear cam. I did some research and found that the way they measure the pic quality is in TV Lines or TVL. Most of these cameras only have 600 TVL. I stumbled across one on Amazon that claimed to have 800 so I jumped on it. I ended up hacking off the plug and splicing it into my OEM harness connection which yielded a pic that was no better, and in some ways, worse than what I started with. I pulled everything back off, put the OEM back on, and resigned myself to live in pixelated rear cam purgatory.
    rmeyer7 likes this.
  9. Mar 17, 2023 at 11:45 AM
    sctomfar
    sctomfar Chasing 700RWHP
    Tom
    Bluffton, SC
    Supercharged Reg cab
    Harrop 2650 supercharger TRD suspension TRD intake Custom exhaust Dirtydeeds cross pipe Fully built bottom end motor Manly Rods Crowder Pistons ARB Stud Kit National Speed Tuned Redesigned fuel system XAT Fuel Rails Twin Demon Fuel Pumps 83cc Injectors Morimoto Headlights
    thats good info
  10. Mar 26, 2023 at 5:27 AM
    old dude
    old dude New Member
    2011 SR5 4WD
    I installed an aftermarket kit from Sparks Toyota in my 2011 6.5 ' bed that did not have the factory unit about 3 years ago. easy install ,uses toyota harness. works great for trailer hook up.
  11. Mar 28, 2023 at 8:56 AM
    ToyStory291
    ToyStory291 New Member
    2007 Tundra SR5
    Stock
    Just acquired a 2007 and the jumper cable that connects to tailgate wiring to the connector under bed was missing. Actually someone had taken tailgate off without disconnecting jumper cable 1st. Had to get that from stealership. But my camera screen is in black and white! Faulty camera or the little viewer screen in headliner?
  12. Mar 29, 2023 at 12:07 AM
    koday0196
    koday0196 New Member
    I bought the wireless backup camera from Amazon (below), and absolutely love it. You don’t have to deal with wiring as the screen and camera wirelessly communicate with each other, and there is no noticeable lag. Also, you can show and unshow the backup space line. The vendor’s customer service is great, also (not sponsored lol). I have had this for 3 years now, and it is still working as intended w/o any problems.
    rmeyer7 and PhotoNerd like this.
