Advice please! 2" lift for offroad use?
Discussion in 'Suspension' started by TundraPro2019, Feb 5, 2020.
  1. Feb 5, 2020 at 12:31 PM
    TundraPro2019
    TundraPro2019 [OP] New Member
    Barthold
    Western Slope, CO
    2019 Tundra TRD Pro
    Hi All!
    So I'm learning lots about lifts... Did a ton of reading here. There are so many choices and different ways of achieving it. I'd like to hear your (expert) opinion please, before I pull the trigger.
    I'm looking to lift my 2019 TRD PRO by 2 inches, with the express goal of getting more clearance for offroading. For now, I'm going to stick with the stock rims and my just bought 275/70/R18 KO2 tires. As an additional complication, I do have Firestone Airbags with Daystar cradles already installed.
    What do you recommend?
    Much appreciated!
    Scott101 likes this.
  2. Feb 5, 2020 at 12:55 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Body lift = 1/3 the increase in raising center of gravity compared to suspension lift.
    Just something to think about, if it matters.
  3. Feb 5, 2020 at 12:57 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Your truck is already lifted 2 inches in the front. Maybe lift the rear an inch or so.
    The best way to get more lift is taller tires. Increases ground clearance
    TundraPro2019[OP] and Berdine like this.
  4. Feb 5, 2020 at 1:00 PM
    timsp8
    NY
    CB has a kit for the pro. But a lift itself won’t necessarily add more ground clearance. With same size tires, your axle hasn’t moved up at all.
  5. Feb 5, 2020 at 1:03 PM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    I don’t have a Pro, but I think the best way to go would be to explore what Coach Builder has to offer. I think their Pro kit is awesome as it allows you to keep your Fox Shocks that are perfectly tuned for the Tundra.
    https://shop-coachbuilder.myshopify.com/collections/frontpage/products/coachbuilder-trd-pro-kit-2015
    They also sell an air bag spacer kit to help solve your rear end dilemma
    https://shop-coachbuilder.myshopify...ilder-airbag-spacer-kit-actual-thickness-1-50
    EDIT: agreed with above, with this kit you can fit 35” tires which will give you the clearance you are looking for.
    Good luck!
    TundraPro2019[OP] likes this.
  6. Feb 5, 2020 at 1:19 PM
    Vizsla
    Vizsla 2 = 2.5
  7. Feb 5, 2020 at 2:26 PM
    TundraPro2019
    Barthold
    Western Slope, CO
    2019 Tundra TRD Pro
  8. Feb 6, 2020 at 10:02 AM
    rustytoys
    rustytoys New Member
    Don't like that 2" height spacer, like Coachbuilders approach better with the 1/2" height spacer/shim.
    If you really care about off-roading ground clearance - then your main goal is simply to stuff the biggest tire possible in there - the lifts only purpose is to accomodate those tires; I like how the coachbuilder kit offers bumper spacers to fit tires - rather than focusing just on height.
  9. Feb 6, 2020 at 10:25 AM
    SC_TRD
    Colin
    Round Rock, Tx
    Seems like a similar front end approach, just more dramatic.
    I will call out that while the prices are similar, the RC lift includes tubular UCAs, which are typically $500+ for a decent pair. Meaning the actual “lift” part of the kit is 1/2 the price of the Coach Builder kit. They are likely able to sell at this price because the kit does not have the same level of craftsmanship quality.
    If you actually want to take the truck off road, you need quality parts, which coach builder is known for. I wouldn’t go for the rough country.
    I know many people on here have the coach builder kit, need one of them to chime in on the abuse they run their truck through and how they like the kit.
    Cheers,
  10. Feb 6, 2020 at 10:28 AM
    AZTundra
    Paul
    Phoenix, AZ
    I'm heading over to Jeff's shop tomorrow. I asked if he could throw my coachbuilder shims and +3 shackles on while he has my truck later this month. He mentioned this kit to me, but I've already got the Coachbuilder items sitting at home. I didn't ask if it was compatible with the Bilstein Pro Shocks or only the Fox. Do you happen to know?
  11. Feb 6, 2020 at 11:08 AM
  12. Dec 9, 2023 at 10:16 PM
    Scott101
    Scott101 New Member
    Just wondering where you ended up with this project on your truck? I have a 2016 Tundra and have the firestone airbags just as you do. I'm wanting to do a 2 or 3 inch lift kit on my truck (or maybe at least a leveling kit to get the front the same height as the back. What did you end up going with and how did you handle the firestone airbags in the back? I'm guessing you probably have to get a spacer kit for the airbags. Please advise and thanks in advance for your help and suggestions.
