Advice on used Tundra
Discussion in 'New Member Introductions' started by GTA, Aug 30, 2023.
  1. Aug 30, 2023 at 2:37 PM
    GTA
    GTA [OP] New Member
    Hi all,
    I'm looking at purchasing a 2020 or 2021 (V8) Tundra with Crew Cab. Any tips on how to inspect and/or what to look for?
    Thanks,
    Gregg
  2. Aug 30, 2023 at 2:49 PM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    If you don't know what you are looking for then you need to take a buddy with you who does know what he/she is looking at.
    At the very least take a decent code reader with you and make sure some goon didn't clear a load of codes 3 miles ago.
  3. Aug 30, 2023 at 2:56 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    2020/21? Nothing to look for yet, just buy it. Well, unless the cats were stolen and replaced with aftermarket. Could be hit or miss.
  4. Aug 30, 2023 at 3:02 PM
    GTA
    GTA [OP] New Member
    I do have a code reader :) I'm just coming around to the fact of how much they're charging. Hard to accept that north of $40k gets you a used truck! That may be just because I haven't bought a car in 20 years.
  5. Aug 30, 2023 at 3:05 PM
    Welcome from NY.
    Get a Carfax report of the vehicle.
    Take it to a independent repair shop or a Toyota dealership and have them go over it.
    Good luck.
  6. Aug 30, 2023 at 7:29 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Definitely take someone with you who knows trucks inside and out. The seller should allow you to have a mechanic thoroughly inspect it.
  7. Aug 30, 2023 at 7:32 PM
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    40k+ for a used? I'd get something brand new with lower trim level for similar price.:notsure:
  8. Aug 30, 2023 at 7:32 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    If it’s low mileage, look for an easy start, no oil leaks, no accident damage and the transfer case shifts into 4H and 4L. Otherwise there aren’t many issues with those years.
