Advice on towing
Discussion in 'Towing & Hauling' started by RoughRoad, Mar 8, 2022.
  1. Mar 8, 2022 at 6:50 PM
    RoughRoad
    RoughRoad [OP] New Member
    14' Tundra 1794
    Bags on the back, TRD sway bar
    Updated Info:
    2014 Tundra 1794 Edition, we bought a travel trailer 25' Lance 7000 lbs dry weight, upgraded total brakes with PowerStop Z36 rotor, calipers, pads & braided lines, added a TRD sway bar & Firestone Air Bags got 91,000 miles on current OEM struts/shocks. There seems to be a lot of bounce in the front end and I am thinking of replacing them with Bilstein 5100's as the front shocks seem to be adjustable. Any thoughts and any other ideas to make this half ton feel more sturdy with this 7,000+ lb trailer on the back. Thanks
  2. Mar 8, 2022 at 6:59 PM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Is that 8000 fully loaded? Do you have a properly adjusted wdh? That’s a lot of weight for a 1/2 ton so a wdh is a must.
    IA_Tundra and GODZILLA like this.
  3. Mar 8, 2022 at 7:01 PM
    I would go with Bilstein 4600/5100/6112 and rears 5160.
    The air bags will kinda work against a LDH if not set up correctly.
  4. Mar 8, 2022 at 7:02 PM
    04rktaco
    04rktaco New Member
    Lee
    California City
    2014 SR5 TRD crewmax 4x4
    All-pro rocksliders RCI aluminum skidplates TRD pro suspension TRD pro exhaust coachman 1inch lift shackles cooper tires
    WD hitch and rear shocks
  5. Mar 8, 2022 at 8:35 PM
    RoughRoad
    14' Tundra 1794
    I have a WD hitch 10,000 lb which keeps the trailer level, the truck just feels a little bullied by the weight being a half ton, not sure what it takes to help the Tundra handle the weight better, but I'm interested in learning.
    The trailer is 7,000 dry which is why I said 8,000 lbs with 40 gallons of water @334lb and another possible 650!!
    I have this WDH w/h trunnion bars---->
    Fastway Equal-i-zer 4-Point 10000lb Sway Control Hitch
    https://www.amazon.com/Equal-i-zer-Progress-90-00-1000-10K-Hitch/dp/B004TR8F5C?th=1
  6. Mar 8, 2022 at 9:14 PM
    AZBoatHauler
    So.Arizona
    It’s a half ton - it is never going to handle towing over 4 tons well.
  7. Mar 9, 2022 at 5:51 AM
    gdiep
    Syracuse, New York
    I would try filling up the water tank when you arrive at your destination (if possible). Reducing the weight by 334lbs will help. Also agree with @ColoradoTJ that the airbags may be working against the WDH. Might want to try towing with them somewhat deflated to test that out. It's a lot of weight for a 1/2 ton. I bought a Titan XD because I needed more capacity than a Tundra but did not want/need a 3/4 ton domestic.
  8. Mar 21, 2022 at 5:51 PM
    FlightMedicRN
    FlightMedicRN New Member
    2020 Super White Crew Max- TSS SR5
    Interior chrome delete- AJT Designs, S&B Cold air intake, 10" BAMuffler exhaust system, color-keyed bumper covers, LED fog lights, TuffSkins interior inserts, black exhaust tail pipe and tip, Peragon tonneau cover.
    Sounds like your camper is very similar to ours in size (27 ft) and weight (7,000 lbs dry). I have a Husky TS- WDH (took several times to get is set just right though). Sumo Springs were installed first but I added Roadmaster Active Suspension- HD about a year ago to beef up the suspension and actually "help" the leaf springs in supporting the load along w/ other benefits. I'm very pleased with the set up I finally got dialed in......We just got back from a Spring Break camping trip (camper in tow) to Big Bend National Park which was over 1,200 miles round trip towing and I thought my 2020 CM did great w/ my set up now. I still have the factory shocks but will change them out at some point w/ Bilstein 4600s'.
    Retired...finally likes this.
  9. Mar 21, 2022 at 6:41 PM
    2019 CM with TRD OR suspension. Bilstein yellow and blues (4600) all around. Properly adjusted WDH is key. Hitch height, angle and bar hanger position is key. Play with these until the truck and trailer sits relatively level with the front fenders dropping when loaded along with the rears. I tow a 7200# dry Outback 292URL. Around 8000# or so loaded with gear, propane and what-nots. I’ve got mine 95% dialed in. Don’t think airbags would help. Drives great in Tow Haul mode. Gotta add extra time and distance to every driving input to add a margin of safety.
    Dansly56 and FlightMedicRN like this.
  10. Mar 25, 2022 at 8:54 PM
    Dansly56
    Dansly56 New Member
    daniel
    I have a 2014 tundra 4x4 crewmax with BFG ko2 33” also have TRD sway bar, Timbrens, RAS, tekonsha brake controller, stock rear bilstein soon to upgrade to 5160 and pro comp 2.5 pro runner front coilovers and pull a 2019 keystone hideout 28bhswe. Dry weight of 6500 and tongue weight of 750. Pulls great with my setup but do want to change my WDH to the Anderson WDH here soon
