Advice on jack placement
Discussion in 'Wheels & Tires' started by justfortun, Jun 29, 2019.
  1. Jun 29, 2019 at 8:36 AM
    justfortun
    justfortun [OP] New Member
    James
    Boston
    2016 SR5
    Hi guys, I’m doing my rear brakes and questioning where to jack up the back end. It seems the most likely spot is the axle, but that is now being taken up by the rear sway bar. Any advice?
  2. Jun 29, 2019 at 8:45 AM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    I believe u can jack from the diff and put jackstands in axles.. cant imagine sway bar eating all that space up. worse case disconnect it
  3. Jun 29, 2019 at 8:50 AM
    justfortun
    James
    Boston
    2016 SR5
    Thanks @ardnutoz
    I jacked up under back door and put a jack stand under. That got the back end up enough to pull the jack and put it under the struts! Damn Little Rock’s
    F9D30C6F-A7A6-41FA-87C1-2B3CA6D67CF6.jpg 297A9131-02F0-464A-8D62-932FC1B70620.jpg
  4. Jun 29, 2019 at 8:50 AM
    justfortun
    James
    Boston
    2016 SR5
    I’m not getting under it, so I’m ok with this for now
  5. Jun 29, 2019 at 9:02 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    That's what I do, jack it up from the pumpkin and slip stands under the axle on each side.
    NewImprovedRon likes this.
  6. Jun 29, 2019 at 9:34 AM
    justfortun
    James
    Boston
    2016 SR5
    Is it ok to grease the caliper piston and the rubber gasket? I put grease between the pad and the reusable metal plate, but I also greased the caliper piston. Wipe it off or leave it? o_O
