Advice on homemade steel bed
Discussion in 'Recovery & Gear' started by cooc1501, Aug 18, 2021.
  1. Aug 18, 2021 at 4:37 PM
    cooc1501
    cooc1501 [OP] New Member
    2004 Tundra TRD off-road
    I'm planning on building an offroad-style bed to replace the one that rotted off my 2004 tundra, I have a ton of 2" square steel tube (1/8" sidewall) that I was planning on building it with and I was wondering if there's anything I should consider in the design before I put it together. I'm not very familiar with common recovery equipment, or methods of mounting storage or equipment. If anyone has recommendations for changes I should make or things I should accommodate for I would be super interested in hearing them. Screenshot 2021-08-18 192147.jpg Screenshot 2021-08-18 192105.jpg Screenshot 2021-08-18 191831.jpg Screenshot 2021-08-18 193521.jpg
    TRDGen and outlaw.taco like this.
  2. Aug 18, 2021 at 6:52 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Is that roll bar supposed to be functional? If so, it'll fold like a lawn chair without some triangulation. Put tubes in an X pattern behind the cab. Take the joint out of the rear bars and run them straight into the main hoop.
    Those fenders and the brackets for the tail lights would get ripped off on a tree if I was driving. :D Or I'd snag my elbow or crack my head on the corner of that thing. Maybe bring the lights in a little and cut the bracket more at a 45 degree angle down to the bed floor. Maybe ditch the fender and get mudflaps.
    I'd probably build a traditional flat deck, or atleast take the angled part out of your design to reduce the amount of work. But I'm pretty lazy. :laughing: I think your design looks good.
    cooc1501[OP] likes this.
  3. Aug 18, 2021 at 7:17 PM
    cooc1501
    this is exactly why I asked because I wouldn't have thought to brace the roll bar and I never would have thought of the rest of that. thanks so much man :)
  4. Aug 18, 2021 at 7:50 PM
    B33
    B33 New Member
  5. Aug 18, 2021 at 8:28 PM
    Half Assed
    Heartland Florida
    10 crewmax
    here is a quick sketch of what I meant about the triangulation and tail lights. Maybe drop the sides down and integrate them into the fenders with mudflaps
    This is a good design too with the bob tail and boat tail. Better departure angle (but shorter bed) and more clearance on the corners. Pretty simple. Definitely more offroad oriented and less utility. Angled sides and instead of flat. Not as easy to mount tool boxes or something along those lines. I guess it depends on what you will really use the bed for.
    Remember steel is heavy lol.
    TRDGen likes this.
  6. Aug 18, 2021 at 9:05 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Name checks out.
  7. Aug 18, 2021 at 9:07 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    I lied. The name doesn’t check out. That’s a lot of work to help out a complete stranger. Good man! Although you’re not staying true to your ethos.
    In all seriousness he’s right you are going to need some bracing and you might want cover or round off some of the sharper edges that are going to bite you.
  8. Aug 18, 2021 at 9:08 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
  9. Aug 19, 2021 at 9:50 AM
    cooc1501
    Dude thank you so much for that you really didn't have to sketch it out for me but I appreciate it so much. gonna do a little redesigning today and this was super useful.
  10. Aug 19, 2021 at 9:52 AM
    cooc1501
    that's a super good idea. ill look up a list of good gear to have and try to make room for it on the bed.
