Advice on ATV in bed of Crewmax
Discussion in 'Towing & Hauling' started by csuviper, May 1, 2017.
  1. May 1, 2017 at 1:46 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Highly considering an ATV. Looking at 2 at the moment. 2000 Polaris 500 or 2006 Honda 500.
    Initially i was hoping to just put it in the bed of the truck and use ramps to get it in there. Hoping to minimize the additional funds spent. Later down the road i can consider a trailer.
    Will i be far enough back that i need a gate saver?
    Or would it be better to go with something like this bed ramp:
    http://www.rizerback.com/shop
    Is it heavy enough that i will need air bags?
    http://toyteclifts.3dcartstores.com/2445--Firestone-Rear-Air-Bags--07-Tundra_p_380.html#
    Was thinking of just the cheap atv ramps from Harbor Freight: [​IMG]
    happyjack87 and MotoTundra like this.
  2. May 1, 2017 at 1:47 PM
    csuviper
    Broomfield, CO
    2006 Honda Rubicon 500
    • Dry Weight: 600lbs
    • Length: 6.92 ft
    • Weelbase: 50.6"
    • Width: 46.8"
    2000 Polaris Sportsman 500
    • Dry Weight: 697lbs
    • Length: 6.75 ft
    • Weelbase: 50.5"
    • Width: 46"
    MotoTundra and Jsena like this.
  3. May 1, 2017 at 1:52 PM
    650h1
    650h1 New Member
    2013 Rock Warrior C/M
    I just bought a 2004 BRP 650XT. It weighs like 700lbs, and I put it in the bed of my truck. It sagged a bit but it was 100% fine. I used ratchet straps on the back bumper of it and anchored them to the bed anchors by the tailgate toward the rear of the bed. Using your bed is fine with ramps, it's a little scary backing out of it but you'll get used to it.
    Jsena likes this.
  4. May 1, 2017 at 1:53 PM
    650h1
    650h1 New Member
    PS you'll be much happier with the Honda...
  5. May 1, 2017 at 1:59 PM
    csuviper
    Broomfield, CO
    No problems with the weight on the tailgate?
  6. May 1, 2017 at 1:59 PM
    csuviper
    Broomfield, CO
    $ dependent
  7. May 1, 2017 at 2:00 PM
    650h1
    650h1 New Member
    No issues with the weight, and that BRP is heavier than either of the ones you're considering.
  8. May 1, 2017 at 2:13 PM
    TheBeast The Beach
    I had a can am DS450. I would load it in the bed without ramps. With my buddy, each of us grabbing one front wheel and hoisting it on tailgate. Then lift rear and push forward. For the way down just grab the rear handle quick and the quad will fall off without hitting the tailgate.
    Then again it is a sports ATV so pretty light.
    The tundra would actually drive better with a load in the bed.
  9. May 1, 2017 at 2:14 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Love my 420
    Y0TA PR0 likes this.
  10. May 1, 2017 at 2:15 PM
    650h1
    650h1 New Member
    They are nothing special, no frills atv's but they last forever and I hate Polaris.
  11. May 1, 2017 at 2:15 PM
    TheBeast The Beach
    that way:
    Jsena and Y0TA PR0 like this.
  12. May 1, 2017 at 2:18 PM
    Brian,
    I was very impressed with the tailgate on my CM and it can take that weight.
    Only advice I will offer is getting a good ramp. I always had the tri-fold ones or something like it when loading ATV's or MX bikes. Get in the habit of always strapping them down as well. Once you see a large ATV slide out from under someone and pile up on top of them like a tub of crap...it is life changing.
    Like these special people:
    One other thing that is certain with ATVs over MX bikes, the ATV usually lands on top of you in an accident, no matter how slow or fast one is going. It is about as consistent as pizza landing cheese side down when dropped.
  13. May 1, 2017 at 2:20 PM
    Over the LINE
    New Orleans
    That's why I bought it, no frills but gets the job done
    blue16, Law323, Jsena and 2 others like this.
  14. May 1, 2017 at 2:27 PM
    Oh, I almost forgot. It doesn't matter what truck bed your going into because they will all fail, but put a 4x4 or something as a tire stop so the front ATV tires are not resting against the front bed. I have also seen people come in to hot and bust out the rear window of trucks as well.
    Law323 likes this.
  15. May 1, 2017 at 3:10 PM
    csuviper
    Broomfield, CO
    So your saying my bed will fail so its not a good thing to put the atv in there?
  16. May 1, 2017 at 3:11 PM
    csuviper
    Broomfield, CO
    Yea don't want the atv to fall off the ramps but i dont think i will have the problem shown in this video. Im smarter than that.
  17. May 1, 2017 at 3:20 PM
    No, it will fail over time if you don't put a block of wood in. The bed bends forward and can touch the cab. That is all I am saying.
    Joeshaker likes this.
  18. May 1, 2017 at 3:22 PM
    As long as they are strapped down, you won't have a problem (as what happened in the video). I have seen some vet riders mess up bad.
  19. May 1, 2017 at 3:22 PM
    csuviper
    Broomfield, CO
    Are you saying to put a block of wood to prevent the wheels from moving forward too far or wood under the tires for additional support?
  20. May 1, 2017 at 3:43 PM
    Medic
    Medic New Member
    Ontario, Canada
    2014 Limited Crew Max
    I have hauled an ATV numerous times and have had no issues with the tailgate.
    I have a block cut so the front bumper doesn't touch the front of the box. As others have stated, over time it will bend forward and touch the cab.
    I also highly recommend tying down the ramps as I have had them kick out while loading. Not a pleasant feeling.
    Last note, I love my Honda Foreman. It is a 1996 and have only done tires and installed a new starter yesterday. Workhorse and will run forever.
  21. May 1, 2017 at 3:50 PM
    Medic covered my answers.
    Law323 and Medic[QUOTED] like this.
  22. May 1, 2017 at 3:51 PM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    $500 used trailer is the way to go. Keep your bed space for a variety of things. Keep your visibility out the rear window. Otherwise you really need locked on ramps to be safe and ensure they don't kick. I've seen straps kick.
    I hauled both in the bed and used a trailer and can tell you first hand trailer works better. Split the price with a buddy or neighbor if needed.
  23. May 1, 2017 at 3:55 PM
    Medic
    Medic New Member
    Ontario, Canada
    I have also seen guys run these for security while in back of truck.
    GNTundra, zcarpenter92 and 650h1 like this.
  24. May 1, 2017 at 4:30 PM
    csuviper
    Broomfield, CO
    I kinda do have a trailer. Was a friends I don't talk to anymore. Last registered in like 2006 or so. Think I can get it registered without talking to the guy?
    It's a fold up harbor freight trailer.
    Law323 likes this.
  25. May 1, 2017 at 4:42 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Not sure but if you have his signature and need a... let's say... duplicate, I'm an expert signature duplicater... :p
  26. May 1, 2017 at 4:43 PM
    Grizzly660
    Grizzly660 21 Army Green Sport
    North Dakota
    2021 Army Green Sport
    20 inch XD Hoss wheels with Nitto EXO Grappler Wetokole seat covers
    Weight will be fine. My advice is get a decent set of ramp. Nothing worst than trying to go up slippery ramps especially when the atv tires are damp or muddy
    ColoradoTJ likes this.
  27. May 1, 2017 at 4:49 PM
    LastCanadianExit
    LastCanadianExit The dude abides...
    Bucks County, PA
    2018 Platinum
    ReadyLift 8" Lift Fuel Trophy Wheels Yokohama 37s
    Just cut the weight in half and ride two wheels, problem solved! ;)
  28. May 1, 2017 at 5:02 PM
    Apply for a home made trailer title. I've had to do that a few times myself. Make sure there is no vin number plate stickers on it.
  29. May 1, 2017 at 5:33 PM
    B_brand
    B_brand New Member
    Brandon
    2017 White SR5 4WD DC
    NFab Steps, LEER Shell, BedRug
    I have a 2006 Honda Rancher. When I had my Tacoma I hauled it in the bed with no issues. Definitely put a piece of wood across the front of the bed like ColoradoTJ suggested.
    I would also go with Honda, they are bulletproof.
  30. May 1, 2017 at 5:52 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I wouldn't worry too much about the weight. I haul a 600 lb Honda Rancher everyday at work, it lowers the rear end on my GMC 1500 maybe an inch or two. But the suggestion about a board or something in front of the tires is a very wise one, the front bed of my work truck is pretty well beaten up against the cab after one year of hauling it around. One of my coworkers took out his rear window with the four wheeler last year.
