Advice needed?!!?!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by abpadilla1794, Sep 18, 2019.
  1. Sep 18, 2019 at 3:48 PM
    abpadilla1794
    abpadilla1794 [OP] New Member
    Alexis
    Black 2016 Toyota Tundra 1794 4x4
    BD316F2B-723D-4BDA-9146-5601CA8EEE0D.jpg 947E08A0-3A16-4F3D-BEDC-F362F874388F.jpg Hey fellow enthusiasts,
    :confused: I’m in need of some advice on my build that I got going on. I’m in process of working on my lift and I am just curious to know if I am gonna run into any issues or if I’ll need anything else in conjunction with what I’m trying to get set up.
    Bilstein 6112/5160 @ 1.9 setting
    Toytech shackle +2
    TRD rear sway bar
    As you can see if the photo, I do have the TRD dual exhaust. I appreciate the advice in advance!!! :thumbsup:
  2. Sep 18, 2019 at 4:07 PM
    AZBoatHauler
    So.Arizona
    What is selling you on the TRD sway bar? How do you plan on using the truck? Lots of off-road, exclusively on-road, mix...
  3. Sep 18, 2019 at 4:32 PM
    abpadilla1794
    Alexis
    Sounds good man!! Thanks
  4. Sep 18, 2019 at 4:36 PM
    NateDiz
    NateDiz Sunday Tunday
    Nathan
    So Cal
    2013 MGM CrewMax TRD
    Trd Pro Suspension, spyder headlights with morimoto HID, Raceline Defender Wheels, AFE filter, Dirty Deeds 8” exhaust
    Ive heard great things about the 6112's. I went with 5100 due to budget. I will save and upgrade next year to 6112. That rear right tire looks pretty cooked...are you getting wheels and tires? just tires?
    abpadilla1794[OP] likes this.
  5. Sep 18, 2019 at 4:36 PM
    abpadilla1794
    Alexis
    @AZBoatHauler it’ll definitely be a mixer of both. i would say a 30/70% (off road/on road)
  6. Sep 18, 2019 at 4:50 PM
    abpadilla1794
    Alexis
    @NateDiz ya that’s the process I am going through right now just rather save up a bit more and get the 6112. I actually have the new set of tires (KO2 275/60/20) sitting in the shed. I got about another couple months or so with the old tires, considering I only drive about 3 miles to work lol
  7. Sep 18, 2019 at 9:01 PM
    AZBoatHauler
    So.Arizona
    In that case you may want to drive it a while after you make the suspension mods without the rear TRD say bar and see if you feel it would help. It will limit your articulation off-road and I frankly don't feel I need to be any more "locked-in" on the highway. Sway isn't an issue for me at all.
  8. Sep 18, 2019 at 9:27 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Should be good to go!:thumbsup:
  9. Sep 18, 2019 at 9:32 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    I paid Toyota to install my 5100's because of the spring work. I would have actually saved money installing a preassembled 6112 coilover in my garage... Live and learn. However, my 5100s have been excellent on road and on trails. The 5100/5160 combo really stiffened things up and gave it a "truck" feel
  10. Sep 18, 2019 at 9:36 PM
    Blaaaaaaack....Welcome from Colorado. Check out Old Man Emu from ToyTec
    Pinay and abpadilla1794[OP] like this.
  11. Sep 18, 2019 at 10:32 PM
    abpadilla1794
    Alexis
    Thanks :thumbsup: Ill definitely make sure to check it out!!
