Advice needed!!! Drive shaft out of balance? Vibration - please watch video!
Discussion in '2nd Gen Tundras (2007-2013)' started by haring, Jan 9, 2018.
  1. Jan 9, 2018 at 8:51 AM
    haring
    haring [OP] New Member
    2010 Toyota Tundra, 5.7 v8. I have recorded a video of my drive shaft today. It starts vibrating/pulsing around 50mph and stops at 57mph. What do you think? Do I need a new drive shaft???
    Most pulsing/vibration you can see around 2:08.
    Here is the video: https://www.youtube.com/watch?v=JPIXIx9Lt8g&feature=youtu.be
  2. Jan 9, 2018 at 9:05 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    that looks like normal movement? :notsure:
  3. Jan 9, 2018 at 9:14 AM
    haring
    I was driving on even pavement. Pulsing vibration came twice during the video when drive shaft was moving up and and down the most.
  4. Jan 9, 2018 at 9:18 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    x2, if anything I'd put new u joints in it before buying a whole new shaft
  5. Jan 9, 2018 at 9:24 AM
    haring
    Does it look normal to you? I feel a weird pulsing vibration between 50 and 57mph....
    Rica25 likes this.
  6. Jan 9, 2018 at 9:30 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Yup looks normal. Speed dependent vibrations can be from a lot of things, brake drag, tire balance, u-joints, cv joints, pretty much anything that spins.
    Rica25 likes this.
  7. Jan 9, 2018 at 10:31 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Are you sure the vibrations you're feeling aren't a tire out of balance? That's often the cause for a speed sensitive vibration.
    Rica25, NewImprovedRon and 4x4_Angel like this.
  8. Jan 9, 2018 at 1:57 PM
    Steve6
    Steve6 New Member
    Tucson
    If you put the vehicle in neutral at those speeds does the vibration stop?
    Rica25 likes this.
  9. Jan 9, 2018 at 2:19 PM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    are your wheels/tires balanced?
    Rica25 likes this.
  10. Jan 9, 2018 at 2:30 PM
    haring
    Let me try it today! I hope putting the transmission into N at 55mph wouldn't damage the transmission....Is it OK to do it?
    Rica25 likes this.
  11. Jan 9, 2018 at 2:30 PM
    haring
    yes!
    Rica25 likes this.
  12. Jan 9, 2018 at 2:40 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Yes. How's the carrier bearing? I'm not an expert, just something I'd check.
    Rica25 and Black Wolf like this.
  13. Jan 9, 2018 at 3:01 PM
    I'd definitely lube everything down there just for shits & grins...Now Alma...don't get any ideas!!!!.
    Rica25 likes this.
  14. Jan 9, 2018 at 3:25 PM
    haring
    Brand new balanced tires.
    Rica25 likes this.
  15. Jan 9, 2018 at 3:26 PM
    haring
    Carrier bearing seems fine. Doesn't wobble when I try to move it. Also, in the video, it seems to be fine.
    Thanks!
    Rica25 likes this.
  16. Jan 11, 2018 at 8:01 AM
    haring
    I will test it today! What if vibration stops when I put into N? And what if it doesn't? What are the conclusions?
    Rica25 likes this.
  17. Sep 14, 2019 at 9:14 PM
    Rica25
    Ricardo
    Tulare
    did you ever figure it out?
