Advice needed. 2010 Tundra facing major repair bill
Discussion in '2nd Gen Tundras (2007-2013)' started by wilbret, Aug 10, 2017.
  1. Aug 10, 2017 at 2:30 PM
    wilbret
    wilbret [OP] New Member
    Hi there!
    I have a 2010 4x4 dbl cab base, with 215k miles.
    Last year, I had issues with AIP and installed the bypass kit to pass emissions.
    Almost 1 year to the day, emissions time comes again, and I get another code, so I ordered the pressure sensor harness to remedy.
    Before that package arrived, my truck died on the highway (during rush hour, no less).
    That was a week ago. The truck has been in the shop for 8 days now. The ECM was toast, which I can verify, as none of my scanners would even connect. I agreed to replace the ECM.
    Now, they want to replace the AIP and the driver computer. We are talking $4500 worth of work in total on a truck that may be worth $10k.
    The mechanic is hesitant to recommend letting me plug the bypass back in and try to drive away. He thinks it will fail again. I worry that if I do this, they will probably void any warranty the ECM has since they know there is a bypass kit involved.
    What would you do? R
  2. Aug 10, 2017 at 2:36 PM
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    Trade IT!:smash: Not worth To keep Dumping money it to it..... For that you can put a nice down payment on a 2014 or newer.:infantry:
    kenomouth64 likes this.
  3. Aug 10, 2017 at 3:33 PM
    wilbret
    What do you supposed you'd get in trade for a truck with this issue?
    I'd love to! Problem is, I don't think I'd get jack squat for it as-is. Looking at pumps on Amazon for $149 each and the guy that posted the how-to says it was 2 hours of labor to do it in his garage.
  4. Aug 10, 2017 at 5:52 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    I would buy a used ECM, install it, have the truck towed to the dealership for programming. Then install the pump.
    Or
    Trade it in.
    You will likely loose 5-6k on the trade-in value, if traded AS-IS.
  5. Aug 10, 2017 at 5:59 PM
    wilbret
    Thanks. I already agreed to the ECM, and they installed it. That was when they "detected" a short coming from the air pump. They disconnected it, and it will only run in LMP mode. I guess I could figure out the parts I need and try to replace the pumps and valves myself. And then trade it.
  6. Aug 10, 2017 at 6:16 PM
    jfrd30
    jfrd30 Lead, Follow, or Get the Hell Out of My Way
    2013 TRD Tundra
    Burn it and collect the insurance. JK!!
  7. Aug 10, 2017 at 6:24 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Is this something that a Toyota extended warranty would cover? Anyone?
    Also I'm sorry to hear about your trucks problems.
  8. Aug 10, 2017 at 6:34 PM
    wilbret
    Thanks. Unfortunately at 215k, nothing is covered. I tried this last year at 180k.
  9. Aug 10, 2017 at 6:34 PM
    wilbret
    If only!
    jfrd30[QUOTED] likes this.
  10. Aug 10, 2017 at 6:46 PM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    I would try and do the bypass drive to a different dealer and act like nothing is wrong/play stupid.
    All most dealers do is start up the vehicle anyway.
    Petroleum 1 and kenomouth64 like this.
  11. Aug 10, 2017 at 6:55 PM
    I would send your ECM out to rebuild. I have done this several times with great results. They have a warranty, and it is a quick turnaround.
    ECMs go bad.
  12. Aug 10, 2017 at 7:16 PM
    wilbret
    Where were you last week? Truck died on my crappy commute... I would have towed it to my house if wasn't going to cost so much. Toyota dealer was nearby. I regret that choice.
    Looks like I'll try the bypass route and unloading it. Ugh.
  13. Aug 10, 2017 at 7:23 PM
    Last week if you're in CO, I would have towed you home.
    So I know Jeep and Dodge ECMs, once you burn the VIN number, you can't use it on another vehicle. I would think Toyota would be similar.
    T-Rex266 likes this.
  14. Aug 10, 2017 at 8:07 PM
    kenomouth64
    Tetrus
    Perhaps, I am not sure, never had to replace one. The ECM rebuild sounds like a good option. Then just use the bypass kit he currently has installed or buy the parts to replace the AIP himself.
    My father replaced the ECM on his Ford f350 6.0. He just bought a new one and drove the truck in limp mode the 5 miles to the dealership, to have them "reprogram it". All in all the new ECM was $300 and the reprogram fee, the ford dealership charged was like $125. They originally quoted something similar to $2800 to replace it. So a significant savings by doing it yourself.
  15. Aug 10, 2017 at 8:13 PM
    Yep, exactly what I am suggesting. Once the dealership burns the program, it stays with the vehicle. Private shops can go as long as they have a Snap On or similar high end scanner/multi tool.
    Great way to save some hard earned cash. The only time I go to dealerships is when I am under warranty. After that, I have my own shops or just do it myself depending on skill level.
    Wvmoonshiner likes this.
  16. Aug 11, 2017 at 11:41 AM
    bicklebok
    bicklebok New Member
    Ronnie
    You seem pretty crafty. Im sure you will figure out something. Im a poor guy, so I would be trying to figure out how to repair it and keep it.
