Advice from the suspension gurus
Discussion in 'Suspension' started by Beardedbeast, Jan 10, 2017.
  1. Jan 10, 2017 at 12:11 PM
    Beardedbeast
    Beardedbeast [OP] New Member
    Killeen TX
    2013 tundra crewmax
    ALOT!
    ok so I've finally got my suspension together just need upper control arms,I'll be running bilstein 6112's and 5160's with Toytec shackles,the question is can I run spacers up front to get 4 inches out of it with adjustable control arms or what have some of you guys done?
  2. Jan 10, 2017 at 2:10 PM
    Why stack it? It's adjustable, right? I would recommend not to stack lifts. Just my .02
  3. Jan 10, 2017 at 2:15 PM
    Beardedbeast
    Killeen TX
    2013 tundra crewmax
    ALOT!
    Yes it's adjustable up to 3 inches but I'm seeing if I can feasaibly get any more out of it without any problems
  4. Jan 11, 2017 at 11:42 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    Anything past 3" will start to require either spindle (if 2wd and some 4wd kits) and/or a drop bracket kit.
    ColoradoTJ likes this.
  5. Jan 11, 2017 at 12:46 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    May I ask what's adjustable to 3". Are you talking about the 6112's or the control arm. I'm just curious, because the 6112's say max setting is 2.75 " @ top setting. Most guy's ive talked to that are running them say they settle down to 2.5"
  6. Jan 11, 2017 at 12:57 PM
    sdhq_offroad
    GILBERT, AZ
    The control arm will not be the adjustable component of the suspension, it will be the shock (in your case the 6112). To do 3", you would have to do an upper control arm and a full replacement coilover
    ColoradoTJ and rons23 like this.
  7. Jan 11, 2017 at 1:05 PM
    rons23
    Ron
    Kill Devil Hills
    Thanks for clarifying that. I didn't think control arms were adjustable.
  8. Jan 11, 2017 at 1:54 PM
    Beardedbeast
    Killeen TX
    2013 tundra crewmax
    ALOT!
    Yeah guys I'll be adding toytec spacers and spc upper arms next week then I'll throw everything on and get her aligned
    rons23 likes this.
  9. Jan 11, 2017 at 2:07 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    According to this link the 6112 has a top setting of 2.5". Maybe it is really 2.75 but settles down to 2.5" and that is why it is shown that way.
    http://toyteclifts.3dcartstores.com...es-Front-Shock-Kit-for-2007Tundra_p_1455.html
    The shock is designed for that height. The more height you add the more that shock can bottom out. If you bottom out the shock too hard you end up with a bent shock because it buckles under the load. Adding small shims will work but not adding multiple shims or combining with a spacer lift.
  10. Jan 11, 2017 at 2:10 PM
    Beardedbeast
    Killeen TX
    2013 tundra crewmax
    ALOT!
    The toytec spacers only add 1/2 to 3/4 of lift so it's not like a 3" spacer,it should be fine for what I'm doing
  11. Jan 11, 2017 at 3:04 PM
    sdhq_offroad
    GILBERT, AZ
    I would still not stack spacers on it. Here is a cool article to read article to read up on. It applies to all spacers, not just 3" spacers. If it were me, since I am already spending so much on arms, I would make it worth the while and spend the extra $$ and get uniball upper control arms. That way it eliminates the weak link in the factory suspension which is the balljoint in the upper arm.
  12. Jan 11, 2017 at 3:26 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Definitely don't stack lifts. But if you do...please take video!
    Also x2 on @sdhq_offroad's comment on control arms. When ball joints fail, the whole fucking spindle flies out and bad shit happens. When uniballs fail...you get squeaks.
  13. Jan 11, 2017 at 4:49 PM
    Beardedbeast
    Killeen TX
    2013 tundra crewmax
    ALOT!
    This is exactly why I made this post,to get different opinions on the do's and dont's with this set up,although I've read many conflicting stories about it I only want to do this once and be done with it.i appreciate everyone's advice and will make my decision based on that.
    ColoradoTJ and Midnighttaco08 like this.
  14. Jan 11, 2017 at 5:07 PM
    Vizsla
    Vizsla pretend2send
    I run 6112s with 2(driver side lean) 1/4" spacers driver, one passenger. Works fine, ended up at exactly 3" lift.
    geno0506 and Beardedbeast[OP] like this.
  15. Jan 11, 2017 at 5:54 PM
    Vizsla
    Vizsla pretend2send
    Dont drive it much, mostly street queen, but when I do, it's like I stole it. Never jumped it or anything crazy, but it has been airborne a time or two, works great so far. No towing. This is the driver side with 2 shims.
    41CBC504-BD99-4608-BB9F-1B93BA4474C5_zps_2abe0c2b95c971f76a76ba33732f7aa693729cfc.jpg
  16. Jan 11, 2017 at 5:57 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Get two coach builder shims and nothing more I'm running them with my fox coilovers you will be at 3in or so and that's all you need anything higher get a drop bracket lift
    Beardedbeast[OP] and GNTundra like this.
  17. Jan 11, 2017 at 5:58 PM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    What kind of downtravel are you getting with that?! I can't imagine much....Also, just curious what do your CV angles look like?
  18. Jan 11, 2017 at 6:37 PM
    Vizsla
    Vizsla pretend2send
    That pic is drooped out. Not sure, 3" is a pretty good MT height while having decent down travel, angles are peachy!
    GNTundra and bandit[QUOTED] like this.
  19. Jan 11, 2017 at 6:40 PM
    bandit
    bandit New Member
    Duh Tundra
    I just wonder what the ride height is and the full droop measurement is with that spacer combo and the coilovers maxed out. I can't see that thing having any down travel at all. max maybe 3 inches of down travel and 5-6inches up travel....For his application though it works no doubt, just curious what the numbers are.
    GNTundra likes this.
  20. Jan 11, 2017 at 7:07 PM
    Vizsla
    Vizsla pretend2send
    Exactly 3" lift, coilovers hit max droop right before the uca's hit max travel, bumps are shimmed 1/4" and they hit plenty before bottoming. That's the best I can do to providing numbers, but it definitely has full travel, droop to bump. Nothing special, but works good for me. This is how it sits, sorry it's dark and cold.
    B248C959-EDB1-4D6E-A332-247CE48D4DC7_zps_620f2a62161f5d8ae9d2ceb5ef4463d2e3eb7013.jpg
    Beardedbeast[OP] and J4RR3N4 like this.
  21. Jan 12, 2017 at 5:25 AM
    jberry813
    Lake Tahoe
    Why would you add shims if you have fox coilovers? Why not just add preload?
  22. Jan 12, 2017 at 6:49 AM
    xtyfighterx
    Ty
    North Idaho
    Does it even matter? Loss of downtravel vs the loss of up travel? 1 shim isn't going to make hardly any difference.
    I didn't want to preload the hell out of them to get 3in of lift so I added one shim and there's hardly any preload at all maybe two threads showing
    A lot of people are running a shim even two with coilovers to either get higher or less preload. I researched it quite a bit before actually doing it.
  23. Jan 12, 2017 at 7:09 AM
    sdhq_offroad
    GILBERT, AZ
    Just because a lot of people are doing it doesn't make it right. You all know what Abraham Lincoln said about the internet.
  24. Jan 12, 2017 at 7:12 AM
    jberry813
    Lake Tahoe
    Of course it matters. We have IFS trucks with leaf springs. You want the bump travel. 1 shim = 1/4 of an inch. And with the shock angle on the front of these coilovers, that equates to almost a 2:1 ratio which means you are sacrificing 1/2" of bump travel. Separate from the pure ride characteristics, Fox, King, ICON, ADS all design their coilovers to bottom out when the LCA's hit the bump stops on bump travel. Now that you added a spacer to the top of your coilover, you push the entire assembly down. Meaning on bump travel, the shock will bottom out a full 1/2" of travel before the bump stops hit. Which means your awesome bad ass shocks you spent a shit load of money on are now the acting bump stops on your truck. There's absolutely nothing wrong with adding preload (to an extent). Now if you're adding a ton of preload, the spring rate on the coils are wrong.
    At the end of the day I don't care who does what to their truck. It's their truck. But adding top plate spacers to an adjustable quality coilover is mind boggling to me. It's like dating a supermodel and only fucking her ugly friend. Each to their own.
    Help, Halfjap, CM-LENNY and 8 others like this.
  25. Jan 12, 2017 at 7:26 AM
    sdhq_offroad
    GILBERT, AZ
    These companies also spend a ton of money in R&D to give you a shock that bolts into the stock location that had millions of dollars spent in R&D to design that length around the chassis. By putting shims on a shock, you are essentially saying "You don't know what you are talking about" to everybody that spent all that money in safely designing suspension for you. Sure, it might be fine for your application, but it still doesn't make it right. Like jberry said, swapping to a heavier rate coilspring (600 up to 650) allows you to put less preload on it and still give you the lift you are looking for.
    I'm just here to pass knowledge to the people that are researching on how to do it the right way.
    Help, CM-LENNY, csuviper and 2 others like this.
  26. Jan 12, 2017 at 7:34 AM
    sc134
    sc134 O.P.S.
    2017 Tundra PreRunner
    Front 2.5 Fox Factory Extended Length Coilovers, Total Chaos Upper Control Arms, Swapped projector Headlights, Tint, Dual Carven Exhaust
    How much lift would you guys say this is? I installed my Coilovers this passed Saturday straight out of the box. At first I didn't think it would lift me much because the ring was down enough.
    Turns out it gave me a higher lift than I expected making the truck slightly higher in the back than the stock rear end.
    The upper control arms uniball looks like it wouldn't take any more "height adjustment" so id consider this a 3" lift right?
  27. Jan 12, 2017 at 7:38 AM
    jberry813
    Lake Tahoe
    Am I doing it right?
    geno0506, CM-LENNY, T-Rex266 and 3 others like this.
  28. Jan 12, 2017 at 7:39 AM
    jberry813
    Lake Tahoe
    Uniball is maxed. You have like 6" of lift.
    Have you driven it around to settle the suspension, or is that how it looks after you lowered it off the jack?
  29. Jan 12, 2017 at 7:44 AM
    sdhq_offroad
    GILBERT, AZ
    Come a long way! Looks good!
  30. Jan 12, 2017 at 7:50 AM
    sdhq_offroad
    GILBERT, AZ
    Post an overall picture of the truck as well. That just doesn't look right. You didn't by chance order a heavier spring on it did you? You do have room to take preload out of that as well.
