Advice for my towing needs
Discussion in '2nd Gen Tundras (2007-2013)' started by Giantsox, May 4, 2021.
  1. May 4, 2021 at 6:18 AM
    Giantsox
    Giantsox [OP] New Member
    Casey
    Hello all. With today's new normals I have found myself working from home and that trend should continue. Home is a 10 acre farm where we currently use my wife's Pilot to haul our horse and utility trailer. Now that I don't have a commute it makes a lot more sense for me to trade in the car and grab a truck. I found a used Tundra 2012 TRD, V8 5.7L with (forget if it's crew or extended cab) and the tow package. Dealer says it can tow 7900 lbs on the bumper. It has a little over 100k miles. 7900 lbs is OK for my current needs and might be OK for future needs. By the time i might need more tow power I could upgrade trucks anyway (3-5 years). A lot of other horse folk have 2500s, but they also have much larger trailers, and I don't know if I'll ever have more then a 2 horse, maybe a 3-4 horse slant. So given what you all know, does this sound like a good fit?
  2. May 4, 2021 at 6:31 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Welcome to the forum from KCMO.
    The Tundra is generally going to be ok for what you're wanting to do. But, if you want more info, check out the threads in the Towing and Hauling section. You'll get a lot of mixed feedback here about the towing experience with a Tundra. Some configurations are rated to tow over 10k pounds, but the owners say they don't feel comfortable with anything over 8k. Others say it pulls just fine. With the truck you're looking at specifically, how it tows will depend a lot on how it's been used in the past. 100k isn't a lot for a Tundra, but a lot can happen over those miles. If it has already been used to tow or haul a lot, the rear suspension could be worn out and need replaced before you can do much more with it. You'll just have to get eyes on it and see what it looks like. Another thing to consider is payload. It's well documented that the Tundra's isn't a lot. Towing 8k, your hitch weight could be ~800lbs or so, which may only leave enough for one person in the cab and an otherwise empty bed. Just stuff to consider.
    Bob and Giantsox[OP] like this.
  3. May 4, 2021 at 7:07 AM
    Giantsox
    Casey
    Thanks BlackSheep! I will read through that forum now. Will be tough to tell what it's been used for unfortunately. Will I be able to see or feel it when I drive if the rear suspension is shot or at least headed that way?
  4. May 4, 2021 at 7:18 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Just an option for you.
    Maybe you can get the dealership to print off any service records for you, assuming its located at a Toyota dealer,
    If not, register here and get the vin to see what Toyota reports for service work.
    I get most, if not all my work done at another shop, but I post all my work done on Toyota service site.
    Helps me remember what/when work was done. I do this for my Tundra and the wifes RAV4.
    Good Luck
  5. May 4, 2021 at 7:48 AM
    BlackSheep
    Scott
    Kansas City, MO
    If the springs look like the one in post #5 of this thread, they’re probably shot. You can also measure from the center of the hub straight up to the highest point of the bottom of the bed side wheel well. Should be +/-25” with an empty bed on level ground. If it’s much lower than that, they’re probably shot. You can also jump up and down in the bed to see how much it sags and how well the shocks damp the rebound.
  6. May 4, 2021 at 9:16 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Good luck in your research!
  7. May 4, 2021 at 6:13 PM
    calisparky
    calisparky New Member
    chris
    2011 tundra crew cab
    "BEAST MODE".....
    Press and release "TOW MODE" button.
    Press and hold "RSCA OFF" button for approximately 5 seconds, give or take. You'll see the lights do what they'll do on the tach. (2011 myself)
    OH BOY!!! I HOPE YOU GOT THE 5.7 CAUSE IT'S' A WHOLE NEW VEHICLE!!!!
    I knocked off, I think it was 3 seconds on my 0-80 time. YEE-HA!!!!
  8. May 4, 2021 at 6:50 PM
    Welcome from NY.
    Good luck with your decision.
  9. May 4, 2021 at 7:28 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Welcome from Alaska,I'm sure you'll be able to answer most all of you questions on here somewhere.
  10. May 4, 2021 at 9:14 PM
    ZiaTundra
    ZiaTundra New Member
    Check for cam tower leak, service records, frame, wheel bearing noise and car fax.
  11. May 4, 2021 at 9:59 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Tundra has 381 horses under the hood. Why would you tow two more behind it? :D
