Advice for my suspension setup?
Discussion in 'Suspension' started by Backstepper84, Feb 3, 2020.
  1. Feb 3, 2020 at 8:20 AM
    Backstepper84
    Backstepper84 [OP] New Member
    2017 White SR5 Crew Max
    Howdy everyone,
    New to the forum, great to be here and really eager to get some work done on the truck. That being said, my first major upgrade will be suspension and rims/tires. As most others have posted many times before, there is a sea of options amidst the aftermarket suspension world. I am just wanting feedback and any additional info there is to be had for what I am looking at. The route I'm wanting to go is no more than a 3" coilover with resi in the front (I like the adjustability factor), with non resi upgraded shocks in the rear, with some brand of shackle. I believe I will only need 1-1 1/2" lift shackle in the rear to achieve look/performance. The ultimate goal for wheels and tires will be one of the matte black Methods (I dig the NVs) with Toyo Tires, preferably as close to a 35" without having to do body chop. I know that the tundra has the drivers lean so I will need to compensate for that after the lift and tires. I am stuck between the BDS coilover kit with Fox shocks, the Kings set up, as well as a Toytec kit and an Elka set up. I believe with the set up I am wanting to run I should probably go ahead and upgrade the UCAs and do the diff drop. Wanting to keep the suspension set up below 4K if I can. I am not going to be doing a lot of high speed off roading, mostly road and occasional off roading but I want a good ride with longevity of the kit. Any advice or any additional info would be greatly appreciated.
  2. Feb 3, 2020 at 9:44 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
    Backstepper84[OP] likes this.
  3. Feb 3, 2020 at 10:44 AM
    Yes there are many options for sure. For what you are wanting, I bet you would be happy with the Toytec Boss kit. @Toytec Lifts can answer your questions and give recommendations. As far as UCA's , the SPC's are popular and Amazon has had the best prices lately. I just got mine for $550.
