Advanced aftermarket alarm wiring questions
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ryooo, Jun 28, 2018.
  1. Jun 28, 2018 at 4:20 PM
    Ryooo
    Ryooo [OP] New Member
    Boynton Beach FL
    2014 CM SC Platinum
    TRD Supercharger 4.5 BDS lift 20” Method Standards sitting on 35 Nitto Grapplers Rigid grill top and bottom with lights AMP running boards Fender flares Magnum rear bumper Rear LED bar Air bags with onboard compressor Brake controller Alpine Navi Alpine amps x 2 Focal Separates front and rear 2 x JL 13s in a stealth box behind the back seat LTE cellular booster Rear seat under locked storage Dynamat from ceiling to floor LEDs all over Bed liner Bed rails Paint protector covering nearly the entire front end and more
    I want to enhance the capabilities of the Viper alarm that’s installed in my Tundra.
    First off, I want to make it so when I arm it the power mirrors fold closed, and then when I disarm it, they open. Does anyone have a diagram of how to wire a relay to trigger it properly?
    Next, the Viper has a remote start, and must have the DEI modul under the dash with the spare key to allow it to start. Currently, when I start the truck with the key, the seat and steering wheel automatically entire my programmed position. However, if I start the truck with the remote start, I must press the memory button for the wheel and seat to adjust. When remote starting, Is there a way to have the seat adjust to the proper position upon turning the key on and pressing the brake pedal?
    Finally, has anyone install auto up/down window automation on the rear window and/or sunroof? These modules are tricky to get to work and I’d love to hear any feedback if you’ve had success or not.
  2. Jun 29, 2018 at 2:29 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I have a Viper Alarm/Remote start and my installers wired my locking the truck switch on the remote allows the front two windows plus the sun roof to open and close with the Viper Remote. Just not the rear windows or back window.
    Haven’t had any luck with the mirrors as I do not have power folding mirrors
    Ryooo[OP] likes this.
