Adjusting my headlights
Discussion in '2.5 Gen Tundras (2014-2021)' started by kcaustin66, Apr 5, 2019.
  1. Apr 5, 2019 at 6:08 PM
    kcaustin66
    kcaustin66 [OP] New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    Does anyone know if this is a special size, my lights are not moving
  2. Apr 5, 2019 at 6:24 PM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    use a 8mm close box wrench (ratchet type preferred) instead of a screw driver
    Sas likes this.
  3. Apr 5, 2019 at 6:40 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    ^ This. Don't use a screwdriver please.
  4. Apr 5, 2019 at 7:42 PM
    JTL
    JTL New Member
    Jon
    Phoenix, Az
    '17 MGM Platinum
    Trd CAI, Trd Dual Exhaust, ESP Locking storage, Center Console Safe, Trd Rear Sway Bar, BFG Ko2, Pioneer Avic 8400nex, Husky Liners, 19 Trd Headlights, iHacker Harness, Tech12Volts Sub Upgrade
    I used a very large, long, phillips and it was fine. Just firmly push it against the back of the guide-channel so the you stay straight. The 8mm close box wrench is interesting though
  5. Apr 5, 2019 at 9:30 PM
    kcaustin66
    kevin
    We tried the 8mm wrench, and turned it but it didn’t seem to work. Before I found this picture about using a screw driver Philips. Just need to raise one side a little to match the other side
  6. Apr 5, 2019 at 9:37 PM
    ifishinxs
    ifishinxs New Member
    Bob
    Cedar city, Utah
    2015 Tundra limited
    None! I tow a boat weekly
    8 mm wrench worked best for me. Passenger side I removed the washer bottle for better access.
  7. Apr 5, 2019 at 10:23 PM
    joeguam
    joeguam New Member
    JOE
    Yes, better to remove the 3 bolts and work smarter and not harder.
  8. Apr 7, 2019 at 2:21 AM
    JTL
    JTL New Member
    Jon
    Phoenix, Az
    '17 MGM Platinum
    I used this and had no problems using my advice from above. Once i figured how to position the screw driver to get it moving it went quick, but does take a lot of revolutions. Not sure why people are saying to stay away from the screw driver?, but seems like removing bolts to use an 8mm wrench is adding another layer to a simple process.
  9. Apr 7, 2019 at 2:34 AM
    joeguam
    joeguam New Member
    JOE
    I gave the option instead of using the screw driver he/she can use a specific size wrench; The initial post ask "Does anyone know if this is a special size", so I answered the question with a answer.
  10. Apr 7, 2019 at 3:16 AM
    Twinky
    07 double cab work horse
    I thought i used an eight mill socket when i messed with mine a while back. Now im im not sure. Either way it worked without much trouble.
    If you're parked with your headlights aimed towards a wall, the closer you are the less noticable the adjustments are.
    And are you marking where the center of the headlight beams are aimed?
  11. Apr 7, 2019 at 10:51 AM
    JTL
    JTL New Member
    Jon
    Phoenix, Az
    '17 MGM Platinum
    I pluralized and shouldn't have. I wasnt calling you out or even referring to your post, honestly. @Sas said to please not use a screwdriver and I was curious as to why when that's how Roman shows us how to adjust them. I should have just asked him in hindsight. :drunk:
  12. Apr 7, 2019 at 11:10 AM
    CyberViking
    CyberViking New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    It's posts like this that make me glad I have the self adjust knob on the dash.
  13. Apr 7, 2019 at 11:21 AM
    JTL
    JTL New Member
    Jon
    Phoenix, Az
    '17 MGM Platinum
    You have to adjust new lights in the housing so they match the previous, before replacement, height levels. The dash adjuster is completely seperate.
    Mickeydog and Sas like this.
  14. Apr 7, 2019 at 11:26 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Not sure why either, I used a screwdriver too, had the lights aimed at my garage wall, works easy but it's a gradual process. Mine are 2018 LEDs, maybe they start seizing with age. I'd use a 8mm ratchet if I had one.
  15. Apr 7, 2019 at 11:27 AM
    CyberViking
    The Ozarks
    Ah gotcha
  16. Apr 7, 2019 at 12:15 PM
    joeguam
    joeguam New Member
    JOE
    Cheers and no problem. In your defense, even the manual calls to use a screw driver.
  17. Mar 4, 2020 at 5:23 AM
    coTony
    Tony
    Montrose, CO
    Where is the adjuster for left and right movement located?
  18. Mar 4, 2020 at 9:27 AM
    coTony
    Tony
    Montrose, CO
    really, that is a first
  19. Mar 4, 2020 at 10:23 AM
    coTony
    Tony
    Montrose, CO
    This is the Toyota Tundra, my other vehicles is what I am referring to. This will be the first time I had to adjust my headlights on any of the 3 Tundra's I have owned.
  20. Mar 4, 2020 at 2:41 PM
    coTony
    Tony
    Montrose, CO
    When I said “Really, that is a first” I was talking about the Tundra only having vertical adjustment since my other non-Toyota vehicles have. My other 2 Tundra’s I have never had to touch a headlight to adjust, they were great vehicles
  21. Mar 4, 2020 at 3:36 PM
    Ericsopa
    Ericsopa Old man and the sea
    I use the screwdriver. It takes a lot more turns than you would think. Just a couple twists will do nothing discernable at 6-8 ft.
    glaster and NewImprovedRon like this.
  22. Mar 24, 2022 at 4:45 AM
    drew.c.114
    drew.c.114 New Member
    Andrew
    Gilbert, AZ
    2021 Trail Edition
    My driveway is sloped, is it recommended to perform this on flat ground?
  23. Mar 24, 2022 at 6:21 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I just went through this.
    I used a screwdriver, although it did slightly round the cross-groove of the screw.
    It takes about 40 revolutions of the screw to go from one extreme to the other.
    I put a mark on the screw with a sharpie pen.
    Because I used a screwdriver I could fairly easily count the revolutions of the screw as I watched the black sharpie mark.
    Once I got one headlight the way I wanted...I believe it was about 17 revolutions form the lowest setting...I just repeated that many revolutions on the opposite headlight.
    I hope this helps.
  24. Mar 24, 2022 at 6:25 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I did this with a screwdriver as well, I had to lower my passenger side headlight a good amount. It took alot of turns. The head size of the screwdriver matters alot. I looked in there and the wrench idea seems like it would be alot more frustrating.
  25. Dec 9, 2022 at 6:36 PM
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
