Adjustable Strut while on truck
Discussion in '1st Gen Tundras (2000-2006)' started by Dustdog, Aug 2, 2025.
  1. Aug 2, 2025 at 9:38 AM
    Dustdog
    Dustdog [OP] New Member
    01, 05 AC 4wd
    stockers
    I ordered 6112s and installed them a while back. They are on 1st clip. Can I lift them up a couple clips while on the truck or is this a bad idea?
  2. Aug 2, 2025 at 9:52 AM
    blenton
    blenton New Member
    Nope. Unfortunately, you need to remove the strut, disassemble it, move the circlip, reassemble, then reinstall. It’s not difficult if you have a decent spring compressor, but takes a couple of hours. The circlip and groove are hidden by the collar; you would need to compress the spring quite a bit to even get access to it, then deal with trying to move the clip while working in a confined space. It’s much easier to simply remove them first.
    rouxster70 likes this.
  3. Aug 2, 2025 at 10:04 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    It's very rare that something isn't possible. But this, not possible. You need to remove and disassemble.
  4. Aug 2, 2025 at 10:16 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Negative. They need to be removed and disassembled to remove the clip and put it in another position.
  5. Aug 5, 2025 at 6:51 PM
    Dustdog
    01, 05 AC 4wd
    stockers
    Glad I asked!
