Adding Turn Signals to 2015 Limited Mirrors
Discussion in '2.5 Gen Tundras (2014-2021)' started by multimoon, Nov 5, 2019.
  1. Nov 5, 2019 at 9:05 AM
    multimoon
    multimoon [OP] New Member
    Garret
    2015 Magnetic Gray Limited-Pro
    So I have a 2015 limited Crewmax, my mirrors are heated and have the BSM markers. I'd like to add the turn signal indicator. I've heard that most of the tundras have the wiring harness already wired up for mirror turn signals that way to can upgrade to tow mirrors. I was looking at upgrading to the Platinum mirrors so I get power fold as well, but that seems like it's really hard.
    So I've settled on trying to just add the turn signal, but I haven't seen much info on that. From what I can tell you can buy just the glass with the lights behind it? Does the Platinum mirror glass have heat, BSM, and turn signals? I don't want to lose the BSM. Could I just swap the mirror glass from the Platinum and connect the turn signal LEDs up and it would work?
  2. Nov 5, 2019 at 9:35 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    If you're current side mirror has the wiring for the turn signals then yes, you can just swap out the mirrors with the built-in LED signal indicators. If not, you need to wire them up for the turn signals to work.
    texasrho83 likes this.
  3. Nov 5, 2019 at 10:01 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Didn’t have to run extra wiring on my SR5 for the Trail Ridge turns to work but I suppose the SR models may need to
  4. Nov 5, 2019 at 10:25 AM
    multimoon
    Garret
    Is there any documentation of what I'd be looking for? Am I just taking the glass out and looking for a connector taped up not plugged into anything?
    Also, does Toyota sell the mirror glass with heat, BSM, and the turn signal?
  5. Nov 5, 2019 at 1:44 PM
    Makoy339
    Super White TRD
    TRD parts
    The harness that comes from cab where the side mirror plugs in to is already pre-wired for turn signals but if your side mirror doesn't have turn signals, then most likely its harness is not pre-wired to connect the turn indicators to.
    In regards to the mirror glass with Heat, BSM and turn signal - @Roman is the best person to ask.
  6. Nov 5, 2019 at 2:27 PM
    multimoon
    Garret
    Do you think that little harness would be it's own part number or part of the mirror housing? If it's it's own harness you can buy I can't imagine it would be too pricey and then I could swap the connector harness as well.
  7. Nov 5, 2019 at 3:28 PM
  8. Nov 7, 2019 at 7:48 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    the wire is in the door on your 2015 limited. you can just tap / splice into it before it goes into the plug at the mirror. I installed signal mirrors from muth, have been trouble free for 4 years.
