Adding Tow Ability.
Discussion in 'Towing & Hauling' started by Cracker, Mar 26, 2017.
  1. Mar 26, 2017 at 1:54 AM
    Cracker
    Cracker [OP] New Member
    Bill
    2016 Tundra Crewmax
    None
    What the best way to keep the 1/2 ton ride.But increase tow ability from 1600 lbs to 2300 Lbs. For the purpose of towing larger 5th wheel camper. Heard about super springs and thought about going this way. Any ideas that may work better?
  2. Mar 26, 2017 at 5:10 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    there are lots of posts on here about towing. the numbers your giving you must be talking cargo capacity. either way you cant increase towing capacity. you can do things that make it perform better within the trucks limits. 1/2 ton trucks are not good with 5th wheel campers
    zcarpenter92, Law323 and Joshua1271 like this.
  3. Mar 26, 2017 at 7:25 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    FlashCulprit and ColoradoTJ like this.
  4. Mar 26, 2017 at 9:03 AM
    That is easy. Buy a bigger truck.
  5. Apr 3, 2017 at 1:13 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Rocket75757 likes this.
  6. Apr 3, 2017 at 1:55 PM
    Tundraplatinum
    2016 Platinum CM
    5000 lbs is misleading you can't put 5000 pounds in a 1/2 ton truck. air bags are great I have them on my tundra but they still don't add cargo capacity. I you fill your bed with 5000 lbs of whatever pump up your air bags to make it look level you have created a pretty dangerous vehicle that looks safe
    ColoradoTJ likes this.
  7. Apr 23, 2017 at 6:51 PM
    Rocket75757
    Rocket75757 New Member
    newbie here,, But I would suggest upgrade tires to E rated first,, and Firestone (or other air bags)... I carry a 2500 lb lance anywhere... I pull 8K lb trailers with ease.....
    My $0.02
    Harris1881 and CM-LENNY like this.
  8. Apr 23, 2017 at 7:45 PM
    You put a 2500 lb Lance in the bed?
    Rocket75757[QUOTED] likes this.
  9. Apr 23, 2017 at 10:16 PM
    Rocket75757
    Lance weight dry 2000 lbs, add 30 gallons of water and some gear,,, yes sir, I carry 2500lbs ease...
    strickdwg likes this.
  10. Apr 23, 2017 at 10:23 PM
    Rocket75757
  11. Apr 24, 2017 at 3:46 AM
    Isn't it great that Toyota adopted the safety towing standard? Sure wish Tundra owners would as well.
    You do realize your overloaded right? By a lot
  12. Apr 24, 2017 at 4:12 AM
    Rocket75757
    Really, why pick on the newbie?
    With upgraded tires (to E rating) and 5000 lb air bags,, I'm well within the industrys safety standards.
    I've owned 3500 chevys and 2500 fords and the Tundra pulls circles around both!
    The transmission , rearend and driveline are better than the ones offered on chevy, ford and dodge in their 3/4 tons,,,, the Tundras brakes are much bigger and better than what other manufacturers offer on their 3/4 ton vehicles too....
    Sir, I see by your profile you own a 3500 GMC and that's great, but why are you dogging me?
  13. Apr 24, 2017 at 4:58 AM
    I would say the same thing to you as I would the site owner. So look in the quoted message in red.
    zcarpenter92 and RatPatrol like this.
  14. Apr 24, 2017 at 7:37 AM
    k9shag
    k9shag New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
  15. May 6, 2017 at 6:00 PM
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    Are there other kits that come with a compressor and controls?
  16. May 6, 2017 at 6:03 PM
    Yes, and they are nice if you want to drop the coin. Now there are remote control systems with fob style controls. Pretty bad ass. This is great for people that change trailers and loads often.
    NewImprovedRon likes this.
  17. May 8, 2017 at 5:54 AM
    TRDProLife
    St.Louis
    m.advanceautoparts.com/p/air-lift-loadlifter-5000-ultimate-air-spring-kit-88299/10649438-P?searchTerm=air+lif+load+lifter+kit
    Has anybody here tried this kit?
  18. May 8, 2017 at 6:08 AM
    I would make sure it doesn't have internal bumpstops.
    Personally, hard to not go with Firestone. So far in my truck ownership, 3 sets of bags. Two where Firestones and they were great. The competition....not so much.
  19. May 8, 2017 at 6:16 AM
    TRDProLife
    St.Louis
    Also, since I have the pro will myh ride height affect the installation of this kit?
  20. May 8, 2017 at 6:20 AM
    I don't know.
    I would get the airbag cradles anyway in your situation having a Pro, and you will not have to worry about tearing bags Offroad.
  21. May 8, 2017 at 6:25 AM
    TRDProLife
    St.Louis
    Smart.
  22. May 8, 2017 at 6:27 AM
    It is an additional expense, and that sucks, but you own a truck that I'm pretty sure your gonna want to take Offroad sometime.
    Hope that helps a little bit.
