Adding the Tow Haul Switch?
Discussion in 'Towing & Hauling' started by Toyo69.5, Jun 28, 2023.
  1. Jun 28, 2023 at 6:30 PM
    Toyo69.5
    Toyo69.5 [OP] New Member
    Mark
    2022 Tundra
    I have a company 2022 tundra. Love it runs great, but it doesn’t have the tow haul switch. I have been trying to get a part number to add. Is the switch all that I need? The wiring is in the condile or will I need more parts and programming?
  2. Jun 28, 2023 at 11:27 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    No no. That switch changes programs in the control units for the transmission (up and downshifting), injectors (port vs direct injection), valves (timing), steering, sway control, abs, and probably the turbos too all for increased control, performance and power.
    *PS- Also de-activates rear collision protection, engine start/stop and modifies BSM detection distance.
    NewImprovedRon, Bob and Mattedfred like this.
  3. Jun 29, 2023 at 7:01 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    That's a great overview, I didn't know that it did all that!
    Bob likes this.
  4. Jun 29, 2023 at 8:08 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    How does TH affect steering and ABS? I was under the impression that TH only changes throttle response and shift points.
  5. Jun 29, 2023 at 9:02 AM
    PNW Tundra Mike
    Back in So Cal
    This new Tundra trailer braking system is integrated with the abs to help control trailer braking and jackknifing in a panic stop. It is reported to actually pulse the electric trailer brakes in conjunction with the trucks brakes. (I question how it knows what the trailers wheels are doing since there are no rotation sensors on the trailer but the RV industry is already testing a new system like that which integrates fully with the truck) The camera’s watching the trailer may be assisting just like they do in trailer assist (don’t know). Steering control pressure is enhanced in tow mode. My 2016 Tacomas steering pressure is increased. (same at low speed) The previous Tubdras do the same. https://support.toyota.com/s/articl...undra, with the 5.7L,a heavy trailer or load.
  6. Jun 29, 2023 at 9:10 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    These guys have third gens.
    GODZILLA likes this.
  7. Jun 29, 2023 at 10:56 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I know. My question still stood though.
    So even in that article you posted (thank you btw) it doesn’t actually say steering is changed or breaking is changed. Just engine breaking, throttle response, and gear holding.
    But that’s interesting on how it’s changed on the new tundra. Technology is definitely there to make things safer for the driver and for others around.
