Adding Shims to Leveling Kit
Discussion in 'Suspension' started by jaredmillerdvm, Feb 18, 2019.
  1. Feb 18, 2019 at 4:19 PM
    jaredmillerdvm
    jaredmillerdvm [OP] Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    Anyone have any experience or see a reason why I shouldn't add two 1/4" shims to my drivers side and no shims on passenger side to get her more level? Right now the drivers side sit about an inch lower than my passenger side, I hear this is normal. TIA.
  2. Feb 18, 2019 at 4:56 PM
    jwl019
    jwl019 New Member
    N.E., Louisiana
    2016 Tundra CM 4wd TSS
    Tacotunes SQ1 package Bilstein 5100's @ 1.5" plus 2 shims Toyotec Shackles at 1" Firestone Ride Rite Airbags SCS SR8's 285/70r18 Nitto Ridge Grappler's Bed Cover Tow Mirrors Windows Tinted Window Visors Weathertech Floor Mats
    In all the threads I have read while looking, most experienced about a 1/2" difference and installed 1 more shim on the driver's side vs the passenger side. Nothing wrong with installing 2 shims on one side, as that is what I am having installed on my truck now except installing 2 shims on both sides since I don't have the Tundra lean on mine. Every truck seems to be different though.
    Mountun Goat likes this.
  3. Feb 18, 2019 at 5:01 PM
    jaredmillerdvm
    Anderson, SC
    Are you adding anything to the rear?
  4. Feb 18, 2019 at 5:05 PM
    jwl019
    jwl019 New Member
    N.E., Louisiana
    I am adding Bilstein 5100's all around and Toytech shackles in the rear. Once the front is installed, I will decide on whether to set the shackles at 1" or 1.5" of lift, the 5100's alone will not lift the rear.
  5. Feb 19, 2019 at 9:44 AM
    jaredmillerdvm
    Anderson, SC
    Any input would be appreciated.
  6. Feb 20, 2019 at 8:52 PM
    jwl019
    jwl019 New Member
    N.E., Louisiana
    I set my 5100's in the middle setting (1.57") and added 2 shims to each side. Gave me right at 2.5" after it settled. Had plenty enough room with the bolts on the strut top hat for them. You will be fine with 2 on the drivers side. Just make sure you are measuring from the center of hub straight up to fender to get your true "lean" measurement and not from the ground where tire pressure may skew it a little.
    jaredmillerdvm[OP] likes this.
  7. Feb 20, 2019 at 8:57 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Is shim just the new word for spacer? :confused:
    jeremyd and DecalsByDesign like this.
  8. Feb 20, 2019 at 9:05 PM
    TXTundra2722
    2015 Black Tundra
    Yes and no, most spacers are larger and the shim is really to correct suspension differences between passenger and driver side, aka, the famous tundra driver side lean
  9. Feb 20, 2019 at 9:06 PM
    jwl019
    jwl019 New Member
    N.E., Louisiana
    Darkness[QUOTED] likes this.
  10. Feb 20, 2019 at 9:10 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    So... little spacers? :D they go on top of the coilover right?
  11. Feb 20, 2019 at 9:10 PM
    TXTundra2722
    2015 Black Tundra
    Yes...........baby spacers
  12. Feb 20, 2019 at 9:11 PM
    iamsmokey
    iamsmokey Smokey the Tundra
    Oahu, HI
    2018 Cement SR5 Off-Road 4x4 Crewmax
    Shims sit on top of the strut assembly where as spacers are inside of them. Shims don't add preload to your coil (don't affect ride quality) where as spacers do.
  13. Feb 20, 2019 at 9:12 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    What he said. I have two .25" shims on the driver's side and one on the passenger's side. With my 5100 leveling shocks at the top setting, I'm a tad under 3" of total lift up front.
  14. Feb 20, 2019 at 9:13 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Spacers I'm thinking of go on top of the coilover, I don't mean the ones that go in with the spring.
    Thanks TX, I keep seeing shims mentioned and never was sure what they're supposed to be. Baby spacers sounds right lol
  15. Feb 20, 2019 at 9:22 PM
    r1-superstar
    DB
    UTAH
    Shims are those two black spacers in the picture.
  16. May 16, 2019 at 9:56 PM
    ab1653
    ab1653 Ew member
    TX
    2014 Tundra
    Did you go with the 1” or 1.5”? What setting did you put the front in?
  17. May 16, 2019 at 10:22 PM
    jwl019
    jwl019 New Member
    N.E., Louisiana
    On the front, I went with the middle setting with 2 shims each side (roughly 2.5"). I set the rear at 1.5" initially, but dropped it down to 1" while installing the Firestone ride rite airbags/daystar cradles since it pretty much kept the factory rake at the 1.5" setting. At the 1" setting, it still has a little rake but only around 3/4" or so.
  18. May 16, 2019 at 11:03 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    If your worried give @Coachbuilder1 a shout out. He's got all your answers. There's many threads that this discussion is talked about.
  19. May 18, 2019 at 5:00 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Yes it will work. But I don't think something is right to begin with. I'm aware of the drivers side lean although I never experienced it. 1 inch down on the drivers side doesn't seem right.
  20. Oct 16, 2021 at 7:17 AM
    Kalashnikov 47
    Kalashnikov 47 New Member
    Minnesota
    2018 Sr5 double cab gang
    Since we are on this topic I want to get these bilstein UCAs but it says not compatible lift spacers..... so am I ok to use a .50 shim for driver side tundra lean??? I'm getting 5100s all around with top setting and +2 cb shackles to keep the rake. Idk shim and spacers are they just 2 different words that mean the same thing??? I'm new to this stuff so don't butcher me haha
