Adding Homelink Rearview Mirror 2014 SR5?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rocko9999, Nov 17, 2022.
  1. Nov 17, 2022 at 11:52 AM
    Rocko9999
    Rocko9999 [OP] New Member
    Has anyone added a Homelink mirror to a 2014 SR5? Curious if there is a harness in the headliner. My mirror is delaminating and mine as well upgrade if I can.
  2. Nov 17, 2022 at 1:29 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    I have a 2014 SR so mine may differ, but I did add a homelink mirror with compass. Long story short, at least in my case, there was no extra harness for the mirror OR for the lighted sun visors. Interestingly enough though, there was a harness for the fog lights, as well as a powered driver seat (no seat warming harness). YMMV though if you have the SR5, but I don't think it'd be that hard to check - just take out two screws from the overhead console and stick your hand around
    Rocko9999[OP] likes this.
  3. Nov 17, 2022 at 1:34 PM
    Rocko9999
    Thanks. I will do that.
  4. Feb 22, 2023 at 1:43 PM
    Rocko9999
    Where did you pull the power/ground for your mirror? Did you tap in to the dome light or run it to the fuse box?
  5. Feb 22, 2023 at 1:46 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
  6. Feb 22, 2023 at 1:53 PM
    Rocko9999
  7. Feb 22, 2023 at 2:16 PM
    Squatting Pigeon
    Holden
    North Texas
    For a homelink mirror?
  8. Feb 22, 2023 at 2:31 PM
    Rocko9999
    WFD473 likes this.
  9. Feb 22, 2023 at 2:32 PM
    Squatting Pigeon
    Holden
    North Texas
    Rocko9999[QUOTED][OP] likes this.
  10. Feb 22, 2023 at 2:35 PM
    Rocko9999
    It is. I just received mine and many others have.
  11. Feb 22, 2023 at 4:13 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Holy crap that’s a steal. I might pick one up just to get the compass back in the mirror.
  12. Feb 22, 2023 at 4:52 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I've been yanking Gentex mirrors from UPull for $5 and installing them in multiple vehicles. Most are 3 wires, ground and 2 hots for the mirror and homelink functions. Just avoid the GM/Chevy iterations as they have a bunch of additional OnStar and other sensor wiring.
  13. Feb 22, 2023 at 5:20 PM
    Squatting Pigeon
    Holden
    North Texas
    $25 shipped is pretty slick for auto dimming and a compass.
  14. Feb 22, 2023 at 11:38 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    I ran it to the fuse box. I've already ran power for my dash cam (SR model, so no Dongart for me). Figured I'd just run another wire to the fuse box the same way.
  15. Feb 23, 2023 at 8:15 AM
    Rocko9999
    Thanks. What fuse did you tap and did you use something like this? https://www.amazon.com/Nilight-5003...ile+mini+fuse+tap&qid=1677168924&sr=8-1-spons
  16. Feb 23, 2023 at 8:17 AM
    Rocko9999
    I saw others who only wanted the Homelink to work with the key on in case someone breaks into the truck. Can I just wire the hot and constant to one switched fuse?
  17. Feb 23, 2023 at 10:18 AM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    I hooked it up to the ACC 7.5 fuse using something like what you linked. The dashcam and the homelink only come on when the power is switched on. You should be able to wire the hot and constant to one switched fuse for the mirror, I'm pretty sure that's what I did too. I will warn though that I think the cheap homelink/compass mirrors from the Kia/Hyundais have the older homelink, so if you have a newer garage door manufactured after I think 2010, the homelink won't work unless you get some kind of signal step down.
    I have one of those newer Chamberlain MyQ garage door motors and the HomeLink didn't work on that until I bought some man in the middle product from chamberlain for the house. It's kind of a PITA because it doesn't retain it's memory through blackouts, so if you get a power outage you have to go through the set up process all over again.
  18. Feb 23, 2023 at 10:35 AM
    Rocko9999
    Thanks. I have an antique garage door opener. I believe the mirror is Homelink version 4, someone may be able to verify. Mirror model HFCHL4.
