Adding height to Bilstein 6112/5160 setup
Discussion in 'Suspension' started by OCretribution, Jul 2, 2022.
  1. Jul 2, 2022 at 3:19 PM
    OCretribution
    OCretribution [OP] New Member
    2012 Black Tundra SR5
    I have had the steins for almost 2 years now, and love them. I am at a point where I would like to add a bit of additional height to the truck and am wondering what the best way might be to go about that.
    For the rear, I was thinking of some coachbuilders to add a couple inches (currently stock height), which would solve that.
    I am more concerned with the right setup for the front, looking to be 5-6" in all. It's currently set at 2.5", so I know adding anything would require UCA which is fine. What would you guys recommend for the front end? I was thinking spindles might be a decent route, but I am no pro.
  2. Jul 2, 2022 at 4:33 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    How about a body lift? 1-3" and it does not raise the center of gravity near as much while not straining the suspension any more than current are all pluses, oh and it can be DIY.
  3. Jul 3, 2022 at 10:38 AM
    OCretribution
    That's a decent idea, I had not thought of that. Thanks!
  4. Jul 3, 2022 at 11:44 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Are you 2wd? Because 4wd and lift spindles are like oil and water - they don’t mix.
    To go 5-6” you’d be looking at a drop bracket lift if you’re 4wd. Then you have to decide if you really want to cut your crossmember out.
  5. Jul 3, 2022 at 1:57 PM
    OCretribution
    I am in a 2wd, and I don't really do much off-roading myself, I just want my truck to look great and work well.
    landphil[QUOTED] likes this.
  6. Jul 3, 2022 at 2:20 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That does give you more options.
