Adding fog lights
Discussion in 'Lighting' started by YankeeRose007, Mar 7, 2015.
  1. Mar 7, 2015 at 8:15 PM
    YankeeRose007
    YankeeRose007 [OP] New Member
    Becca
    2009 Red Tundra
    ArmorKing Tonneau Cover
    2009 Tundra... Did not come with fog lights... How hard is it to put in fog Lamps in the wells where they're supposed to go?
  2. Mar 8, 2015 at 9:49 AM
    Chuckt
    Chuckt New Member
    I have seen kits with all the pieces about $300 I think.
    Also seen somebody post a DIY where the plastic cones were model to fit after market lights.
    I'm to cheap for the first and not skilled enough for the other.
  3. Mar 8, 2015 at 6:36 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I would say it all depends on the kit you buy and how perfect you want them to look. If you have experience adding electrical pieces and running wires it shouldn't be too hard. If not, it will probably be a pain!
    Here is a complete OEM kit with everything you should need...
    http://www.trdsparks.com/displayparts.php?Mdl_dtl=655&Part_cat=24&parts_id=2033
    Here is just the mount kit (no lights or anything though)
    http://www.4wheelparts.com/Lighting...g.aspx?t_c=14&t_s=451&t_pt=3161&t_pn=PIA30352
  4. Mar 2, 2016 at 12:59 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    I have been thinking about installing aftermarket lights in the black plastic filler cones and then spraying the cones with that new spray on chrome.
