Adding Cruise Control to my 2001 Toyota Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Rmauldin, May 9, 2020.
  1. May 9, 2020 at 10:05 AM
    Rmauldin
    Rmauldin [OP] New Member
    Ramsu
    2001 Toyota Tundra
    I recently acquired a 2001 Toyota Tundra due to my father-in-laws death. It does not have cruise control. Can you tell me if the truck is pre-wired for cruise control, and or there any more parts required other than just the cruise control lever on the steering wheel?
  2. May 9, 2020 at 10:07 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Hey Ramsu, moved your thread to the awesome 1st gen section. I’m sure those members would know and have an answer for you shorty!
    Tundra2 likes this.
  3. May 9, 2020 at 10:10 AM
    Rmauldin
    Ramsu
    2001 Toyota Tundra
    Thanks Pinay. I am new to this. Appreciate and thanks.
    Tundra2 likes this.
  4. May 9, 2020 at 10:11 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    No worries! Any other questions feel free to ask! Great community here, hope you stick around! :)
    Schcoman likes this.
  5. May 9, 2020 at 1:07 PM
    Professional Hand Model
    Hand Protectors
    Could be wrong here, but I think Cruise Control wasn’t an option until 2002. Not sure but some experts will hopefully chime in.
  6. May 9, 2020 at 1:27 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’m pretty sure it was an option from ‘00, at least here in Canadia.
    OP, since the earlier throttle bodies are cable operated, installing cruise involves installing an actuator with throttle cable, cruise module, switch stalk, likely a different 4-pin brake pedal switch... And I don’t know if any Tundras were pre-wired or not.
    I did this with used OEM parts on my ‘01 Corolla years ago, which was not pre-wired. It was a lot of work.
    If you’re serious, find another ‘01 Tundra with cruise, compare to yours to see if it is pre-wired to begin with.
  7. May 9, 2020 at 2:04 PM
    Rmauldin
    Ramsu
    2001 Toyota Tundra
    Thanks for your reply. I removed the air bag on the steering wheel. It has the male plug to receive the cruise control switch. I know this does not prove it's available or pre-wired.
    landphil and Tundra2 like this.
  8. May 9, 2020 at 2:07 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    This might be a good question for @empty_lord.
    Very knowledgeable fella!
    My personal gut instinct says that since you have the plug odds are that the rest of the wiring would be there. I am NOT an expert so do not take my word as gospel.
    Also, welcome to the community.
    landphil likes this.
  9. May 9, 2020 at 2:11 PM
    Rmauldin
    Ramsu
    2001 Toyota Tundra
    Thanks for your reply and info Noah.
    Tundra2 likes this.
  10. May 9, 2020 at 2:55 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That is a good sign. The connector I’d be most excited to find would be the actuator connector under the hood, based on the sketches I think it might sit behind the airbox???
    The connector looks like the one on this actuator:
    And some art from Toyota’s parts diagram:
  11. May 9, 2020 at 3:32 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    wrong. My 00 and my 01 parts truck have it.
    shamelessplug/
    @OP, if you need any parts HMU.
    /shamelessplug
  12. May 9, 2020 at 3:37 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Ha! I almost tagged you here after seeing your part-out thread. Any chance of a picture of the location of the cruise actuator?
  13. May 9, 2020 at 3:42 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Yep, I’ll get that tomorrow.
    landphil[QUOTED] likes this.
  14. May 9, 2020 at 7:24 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
  15. May 10, 2020 at 6:40 AM
    Rmauldin
    Ramsu
    2001 Toyota Tundra
    Thanks to all. I'll check and see if the truck has this.
  16. May 11, 2020 at 7:27 AM
    The 1st Gen tundras are drive by wire. I don't believe there is any need for additional actuators. Just need the switch and to make sure the wires / fuses are all hooked up. I've read that you may need a different brake switch though. A 4 prong instead of a 2 prong? someone else may have more info on this.
  17. May 11, 2020 at 7:31 AM
    empty_lord
    05 rollover special
    00-02 used drive by wire but involved a gas pedal cable.. weird setup
    Tundra2 likes this.
  18. May 11, 2020 at 7:31 AM
    Upon further inspection my 00' is still cable actuated.
    Tundra2 likes this.
  19. May 11, 2020 at 7:42 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    Tundra2 likes this.
  20. May 11, 2020 at 2:27 PM
    Hand Protectors
    lsaami and landphil like this.
