Adding a brake controller
Discussion in 'Towing & Hauling' started by YotaFan05, Jul 10, 2023.
  1. Jul 10, 2023 at 7:10 AM
    YotaFan05
    YotaFan05 [OP] New Member
    NE OH
    2011 Tundra Crewmax
    We are looking to purchase a used travel trailer that is located about 3 hrs away.
    The specs are;
    HITCH WEIGHT 557 lb.
    UVW 4,493 lb
    Do I need to add a brake controller to pick this up? I currently don't have one, or a wdh. Thanks.
  2. Jul 10, 2023 at 7:21 AM
    Yes
    Cpl_Punishment likes this.
  3. Jul 10, 2023 at 7:25 AM
    2mchfun
    On a three hour highway tow you will want a weight distribution hitch and brake controller. Your going to need both eventually anyhow. Might ask the seller if they have a hitch for sale.
    KingsAustin likes this.
  4. Jul 10, 2023 at 7:27 AM
    You honestly could pick it up and move it without either, but the brake controller is a big safety item. Not sure what traffic or terrain looks like on your trip. You could get by without the WDH, but it is recommended by Toyota for a trailer that size. Would help with sway as well.
    KingsAustin and Cpl_Punishment like this.
  5. Jul 10, 2023 at 7:33 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Definitely need the brake controller. I believe it's recommended for any trailer over 2000 lbs. Toyota says to use a WDH if your trailer is over 5000 lbs so you'll need one of those too. You might technically be ok towing it home empty with brakes but no WDH but I'm not sure why you'd want to.
  6. Jul 10, 2023 at 9:31 AM
    YotaFan05
    NE OH
    2011 Tundra Crewmax
    Confirmed, thanks everyone! I'll look into a p3 controller (seems to be the common one recommend).
