Adding a backup camera?
Discussion in '2nd Gen Tundras (2007-2013)' started by Dorks68, Dec 31, 2020.
  1. Dec 31, 2020 at 6:55 PM
    Dorks68
    Dorks68 [OP] New Member
    Derek
    2010 Rock Warrior
    I have a 2010 Rock Warrior CM. Non Navi head unit. No camera in tailgate handle.
    What would be my best option for adding backup camera?
    Aftermarket head unit and aftermarket tailgate handle with camera?
    Aftermarket rear view mirror and aftermarket tailgate handle/camera?
    Is the truck pre-wired for either of these options?
    I would like a new head unit with apple CarPlay of that helps :)
    Thanks!
  2. Dec 31, 2020 at 7:03 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    The truck should be pre wired for the camera. You'll have to add the little harness from behind the rear bumper up and into the tailgate, add the Toyota tailgate handle with the camera, then add the drop down camera that goes in the overhead console. You can see the parts here:
    https://tailgatecamera.com/collecti...e-backup-camera-and-lcd-monitor-for-2007-2013
    If you have any desire to put in a different head unit, an aftermarket setup will cost less and give you a far larger screen.
    70m4h4wk, Silverghost and Dorks68[OP] like this.
  3. Dec 31, 2020 at 7:07 PM
    TheBeast The Beach
  4. Dec 31, 2020 at 8:02 PM
    Dorks68
    Derek
    2010 Rock Warrior
  5. Dec 31, 2020 at 8:09 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Added the Masters tailgate handle / camera from Amazon, $100. Coupled to Pioneer NEX8100. Works great.
    Masters assembly comes with wire to run up to the HU. Had local install shop do the install for like $150.
  6. Jan 1, 2021 at 10:22 AM
    TheBeast The Beach
    I like it a lot. For the price, it cannot be beat and is very compact so you can add an external amp behind it. I ran brand new wires. Easier than trying to figure out Toyota harness.
    the alpine HU has the option for a second camera input so I might add one to the front.
  7. Jan 1, 2021 at 3:51 PM
    Gto7419
    Gto7419 New Member
    2010 Tundra
    I did a good bit of research and ordered coolint? (I think) Rearview mirror and camera - each one separately. I drilled a hole in the tailgate handle. Works perfect.
    Trooper2 likes this.
  8. Jan 5, 2021 at 5:19 PM
    TXTundraFan
    TXTundraFan New Member
    If you want to avoid the overhead console for the reverse signal, you an tap into it behind the headunit in one of the wiring bundles. Just pop open the back cover and tap your wire there. I did this same install in my Tundra with the Alpine radio. I wanted to be able to use the backup camera whenever I'd like as well as when the truck goes into reverse.
    Dorks68[OP] likes this.
  9. Jan 5, 2021 at 6:38 PM
    Dorks68
    Derek
    2010 Rock Warrior
    That is the route I would prefer. Do you remember which wire it was?
  10. Jan 5, 2021 at 7:00 PM
    TXTundraFan
    It wasn't a wire; it was a light grey bundle that is taped to the dash support bar. Here's a picture of it from when I did my install: https://www.tundras.com/threads/backup-camera-wiring-through-tailgate.77256/page-2#post-1966452
    Use a multimeter with the continuity test to verify that it sees voltage only when you put it in reverse. It will be the series of 3 metal posts there. I stuck the backup sensing wire for the aftermarket wiring harness on this set of "posts" and closed the plastic lid and taped it really good.
  11. Jan 5, 2021 at 7:53 PM
    Dorks68
    Derek
    2010 Rock Warrior
    Awesome. Thank you. Would solder be a better solution? Is it accessible enough for that?
    TXTundraFan[QUOTED] likes this.
  12. Jan 5, 2021 at 8:00 PM
    chickunfut
    chickunfut Low-buck Ramp Truck
    Fort Worth, TX
    2007 Tundra Crewmax
    You can remove the plug with the flap on it and solder to the metal behind the flap. Just be quick because the heat transfers into the metal and will start melting the plastic.
    TXTundraFan likes this.
  13. Jan 6, 2021 at 7:11 AM
    TXTundraFan
    I thought about soldering the wire to it but I was concerned about heating up the plastic around it, so I just taped it directly one the set of 3 posts in that connector and then taped the flap back on the wire harness itself.
  14. May 26, 2021 at 11:18 AM
    Scooter916
    Scooter916 New Member
    Nathan
    08 5.7l CrewMax SR5 2wd,
    custom shift knob, Hooke Road front and rear bumpers, 12v Solutions Remote Start
    my 08 SR5 didn't come with a back up camera, if I get the tailgate handle with camera, is the truck already pre-wired?
  15. May 26, 2021 at 11:47 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Subscribe
  16. May 26, 2021 at 12:11 PM
    BenAZ
    BenAZ New Member
    Ben
    Prescott Valley, AZ
    2007 Slate Metallic Double Cab
    My 2007 SR5 was pre-wired. I did the homelink mirror with the tailgatecamera.com plug and play tailgate handle. If you look under the rear of your truck there should be a connector in the rear close to the bumper on the passenger side that has a cap on it instead of a connector for the rear view camera. Its white IIRC.
  17. May 26, 2021 at 12:54 PM
    Scooter916
    Nathan
    Sweet, I'll be pulling the rear bumper off this weekend to replace with a new one so I'll have a look around.
