Adding 2nd trans cooler
Discussion in 'General Tundra Discussion' started by Tundra_wil, Nov 15, 2023.
  1. Nov 15, 2023 at 7:57 PM
    Tundra_wil
    Tundra_wil [OP] New Member
    Has anyone else added a 2nd trans cooler to a truck with an OEM cooler ? I have a 2016 with the thermostat pinned and was seeing converter temps as high as 255 and pan temps around 230 towing in the mountains. I had planned on adding the hayden cooler and running it through that one first as it has an internal thermostat to allow temps to be somewhat normal until it’s really needed then off to the oem cooler . Thoughts ?
    tarathetundra likes this.
  2. Nov 16, 2023 at 12:39 AM
    tarathetundra
    tarathetundra New Member
    Nate
    2018 white CM
    37x13.50R18
    Interested in this as well or if anybody knows a larger transmission radiator/cooler that would replace factory one in a a plug and play fashion?
  3. Nov 16, 2023 at 12:42 AM
    When you got these high temps in the mountains, what were you doing? Were you in 4Hi? 4Lo? Speed of travel? Going up or down hills? Dirt or pavement? How many miles on the truck? Has the transmission ever been serviced?
    Lots of missing info that needs to be filled in before I'd spring for a second cooler.
    A common issue that heats things up super fast is people using 4Hi and driving slow on off road trails/rough roads, especially uphill. If you were doing this, you probably don't need a new cooler, you just need to use 4Lo at speeds sub 20 MPH as it will lock the converter up and keep it from building so much heat.
    If that's not what you were doing, details on what you were doing may help with solutions.
    BravoDeltaRomeo, reywcms and Bammer like this.
  4. Nov 16, 2023 at 3:59 AM
    Tundra_wil
    truck has 117k trans serviced 1k miles ago . Just in 2WD pulling steep grades maybe 50 mph . Rpms are to low to hold speed in 4th so I have to be in 3rd unlocked converter just builds heat super fast.
  5. Nov 16, 2023 at 4:00 AM
    Tundra_wil
    I was going to use the Hayden 699 cooler - I would say it’s pretty plug and play especially if you just bypass the old cooler - just make your own mounts
  6. Nov 16, 2023 at 4:06 AM
    50 MPH, even on a steep grade, should have plenty of airflow for a truck equipped with any kind of transmission cooler. I'd be checking what is currently installed to see if its fins are damaged or clogged, or possibly if there is corrosion in the cooler that is preventing flow. Just my opinion.
    ColoradoTJ likes this.
  7. Nov 16, 2023 at 4:16 AM
    To add:
    Check the clutch fan operation. You may be not getting enough air flow.
    The factory cooler is more than adequate to cool that transmission especially since the thermostat is pinned open.
  8. Nov 16, 2023 at 4:32 AM
    Good thought! I didn't even think about the fan possibly struggling.
  9. Nov 16, 2023 at 4:39 AM
    Tundra_wil
    my last 2016 tundra did the same thing. These long mountain passes in AZ are tough. Should I be less focused on the converter temp?
  10. Nov 16, 2023 at 4:42 AM
    Pan temp is the important one. The converter will always get quite a bit hotter than the pan, but it will also cool so long as the pan temps are down. How much are you towing? Are you in tow haul mode for the pull? Are you using cruise control? IIRC using cruise will disable certain behaviors of tow haul mode, so you shouldn't be using both in hilly terrain. @ColoradoTJ correct me on that if I'm mistaken, please.
    We have 6-8% grades all over and I've towed some and never felt the Tundra was heating up excessively, but I also towed infrequently enough that I didn't have a way to read the temps.
  11. Nov 16, 2023 at 4:48 AM
    We'll pan temps is already cooled fluid...
    GODZILLA[QUOTED] likes this.
  12. Nov 16, 2023 at 4:53 AM
    Right, but that's also what is going to cool the converter, yes?
  13. Nov 16, 2023 at 5:02 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Correct. Pay more attention to pan temperature. TC temp is more to show that the TC is locked or unlocked.
  14. Nov 16, 2023 at 5:10 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Windshield washer kits are under $20 on Amazon. Install one, only use a nozzle that sprays, not streams. Evaporating water will keep anything from overheating. Engine will also benefit from extra cooling in mountains.
    mayan and Retired...finally like this.
  15. Nov 16, 2023 at 5:16 AM
    Retired...finally
    Interesting idea you have there. It surely would work.
  16. Nov 16, 2023 at 5:39 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I'd use distilled water to prevent calcification on the fins....
  17. Nov 16, 2023 at 5:45 AM
    Retired...finally
    Good point.
  18. Nov 16, 2023 at 5:53 AM
    Absolutely. The hottest fluid is coming out the converter heading to the heat exchanger. They are both important temps to monitor.
  19. Nov 16, 2023 at 8:53 AM
    tarathetundra
    Nate
    2018 white CM
    37x13.50R18
    With a pinned transmission how long till the trans gets to a operating temperature?
  20. Nov 16, 2023 at 9:49 AM
    Tundra_wil
    I get to 180-190 fairly quick
    tarathetundra[QUOTED] likes this.
  21. Nov 16, 2023 at 9:51 AM
    Tundra_wil
    so I just have tow haul on . Is s5 or mainly s4 . I don’t wana tow at 75-80 so at 3-4K ish in s3 I chug up the mountains at around 55-60 but the passes are super long so by the time I get to the top my TC is already hot
  22. Nov 16, 2023 at 9:52 AM
    Tundra_wil
    yeah I just wish I could get lock up in 3rd. For me to be at like 4K ish in 4th to hold speed I’m doing 75-80 which I don’t want to tow 7500lbs that fast so I have to be in s3
  23. Nov 16, 2023 at 10:06 AM
    I towed pretty heavy with my 2012 Tundra (reason I moved up in towing class) and never seen these kinds of temps. Makes me wonder if something is wrong internally that even a second cooler in series won't help?
    GODZILLA and Black@Blue19 like this.
  24. Nov 16, 2023 at 10:57 AM
    Tundra_wil
    im not to sure , I will say that my previous 2016 tundra same trim level / miles / tire size and everything had the same temps climbing the same hills . I sold my last one for a duramax / sold my trailer / sold the truck then back into a tundra lol
    GODZILLA and ColoradoTJ[QUOTED] like this.
  25. Nov 16, 2023 at 1:02 PM
    We are polar opposites :thumbsup:
    GODZILLA likes this.
  26. Nov 16, 2023 at 4:46 PM
    You found the yin to your yang.
  27. Nov 16, 2023 at 8:26 PM
    Retired...finally
    Anyone purchased or considered purchasing a deeper pan with cooling fins? For me keeping my 21 In warmer climates year round it seems like a good idea. Especially the extra capacity. I'm lucky to have a sister that owns a Gen II and has a doctorate in industrial engineering specializing in heat transfer. I may run it up the flagpole and see if she salutes it.
  28. Nov 17, 2023 at 6:51 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Maybe this is interesting to you??
    https://sdhqoffroad.com/products/09-21-toyota-tundra-ab60-transmission-hi-tek-trans-pan
  29. Nov 17, 2023 at 7:02 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I level out @165-ish after about 15 minutes.
    even with the engine coolant temp hitting 190.
  30. Nov 17, 2023 at 7:28 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    It might be worth it to get an HPtuners MPVI2/MPVI3. Buy the tuning credits and you will have full access to tune things like converter lockup and such. Then you can read up on this thread and toy with changes yourself to see what kind of improvements you can make as far as TC lockup in the different gears. The factory tune does not allow 3rd gear lockup unless the coolant temp is over 208, and or the transmission fluid is over 257 if I recall from a post in this thread. You can change that if you feel comfortable as outlined in here.
    https://www.tundras.com/threads/instructions-for-custom-tuning-the-truck-with-hptuners.70590/
    nobodyintexas likes this.
