Adding 18x9 +18mm wheels to Stock TRD Pro with 295/70’s. Will it clear?
Discussion in 'Wheels & Tires' started by Ron_Pro, Mar 26, 2021.
  1. Mar 26, 2021 at 7:55 PM
    Ron_Pro
    Ron_Pro [OP] New Member
    California
    2020 Tundra TRD Pro CrewMax
    I have a stock 2020 TRD Pro with 295/70/18 Ridge Grapplers.
    I am planning on adding 18x9 wheels with a +18mm offset. Will it clear without a BMC? I know I will have to push in the front liner to clear, but I was just wondering about the body mount clearance.
    Thanks in advance!
  2. Mar 26, 2021 at 8:20 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Yeah it should clear the body mount. I had to remove the mudflaps and shim the bumper along with pushing the plastics forward. Just be ready with the heat gun. Oh, and you’ll probably need to trim/bend the skid plate.
  3. Mar 26, 2021 at 8:30 PM
    Ron_Pro
    California
    Thanks for your response. Mud flaps are off already due to the 295’s. The front liner was pushed in when I had spidertrax spacers. I’m good to go with that, I just wasn’t too sure if +18mm would clear the body mount. However, I didn’t even consider having issues with the skid plate. Good to know. Thank you!
  4. Mar 26, 2021 at 9:55 PM
    redhat
    redhat Leadfarmer
    Jacob
    Sacramento
    2019 TRD PRO
    Nothing but good stuff.
    My 285/70’s with SCS ray10’s rub in reverse partially turning.
  5. Mar 26, 2021 at 10:23 PM
    Ron_Pro
    California
    Where does it rub?
  6. Mar 27, 2021 at 4:54 AM
    redhat
    redhat Leadfarmer
    Jacob
    Sacramento
    2019 TRD PRO
    Where the mud flap used to be on the plastic. I was hoping removing the mudflap would be enough....but it’s just a small rub.
    Ron_Pro[OP] likes this.
