Adding 12v charger to back of bed
Discussion in 'General Tundra Discussion' started by Tundra1078, Jul 3, 2018.
  1. Jul 3, 2018 at 12:09 PM
    Tundra1078
    Tundra1078 [OP] New Member
    Peter
    Los Angeles
    2018 White Platinum 4x4
    TRD dual exhaust, sway bar, TRD skid plate, grab handle (future), husky liners
    Has anyone added a 12v outlet to the back of the bed. Going on a long road trip so would like to add a cooler to the back.
    Coolhardy likes this.
  2. Jul 3, 2018 at 12:22 PM
    Well here is my experiences with this.
    On my 14 Tacoma, I couldn’t even run a crock pot off the inverter.
    So, if you’re dead set on this, make sure you buy a big enough inverter, may need a bigger alternator.
    Personally, I would just buy ice. However, you can always wire up a 12v plug in the bed and run a refrigerated cooler.
    https://www.amazon.com/Interior-Coolers-Refrigerators/b?ie=UTF8&node=15735671
    jeremyd and Pudge like this.
  3. Jul 3, 2018 at 12:40 PM
  4. Jul 3, 2018 at 12:47 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Also you can try to find a place locally that sells dry ice. Should last a while.
  5. Jul 3, 2018 at 12:49 PM
    Get a YETI and they’ll remain ice cold as long as there’s ice in it.
  6. Jul 3, 2018 at 1:22 PM
    COTundraRoamer
    COTundraRoamer New Member
    Dustin
    Denver, CO
    18' Platinum CM
    Fox 2.5 DSC front, Fox 2.5 DSC rear. JBA UCA. SCS Ray10 custom powder coated on 285/75r18 Duratracs.
    I did. Ran a fused 6 gauge wire from the battery to the bed, added a quick disconnect under the bed and then continued the line up to the back passenger side bed rail. Used a blue sea systems fuse block to run bed lights and two 12v sockets for camera chargers and ARB fridge.
    CappyKD and Pudge like this.
  7. Jul 3, 2018 at 6:07 PM
    Tundra1078
    Peter
    Los Angeles
    I have a 12v cooler that’s works great. With the passenger seat all the way to the front it fits perfectly behind it and keeps our drink and food cold. I want to keep the cooler in the back so we can have more space.
  8. Jul 3, 2018 at 6:32 PM
    Pudge
    CT
    Should be easy enough to run a wire from the battery along the frame and up through the bottom tailgate, maybe through one of the drain holes in the front of the bed?
    Tundra1078[OP] and ColoradoTJ like this.
  9. Jul 3, 2018 at 6:36 PM
    Pudge
    CT
  10. Jul 3, 2018 at 6:52 PM
    ZPMAN
    Minnesota
    I think there is 12V on one or both of the trailer plug in's that you could use for a inverter or outlet.
    Pudge likes this.
  11. Jul 3, 2018 at 7:10 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    In the middle of doing it. Will post pics soon
  12. Jul 3, 2018 at 7:12 PM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
  13. Jul 3, 2018 at 7:42 PM
    Vizsla
    Vizsla 2 = 2.5
    I don’t know, but you would need a big wire to run a fridge etc.. This is my loom run to the back for chase and bed lights. That’s 32’ of wire to get from battery to rear bed corner proper.
  14. Jul 3, 2018 at 8:23 PM
    COTundraRoamer
    Dustin
    Denver, CO
    18' Platinum CM
    My Fridge doesn't draw much at all but the camera chargers do. I think the thermoelectric coolers are quite a bit higher draw than a fridge. I used 6 gauge to the bed. ARBs kit is 10 gauge and has worked in my Jeep for years. Probably 30 feet or so overall. Grounded behind the tail light.
    BTBAKER and Pudge like this.
  15. Jul 3, 2018 at 10:23 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    10 gauge is good for 30 amps. I can’t imagine anything you’ll be powering will need that much current.
  16. Jul 3, 2018 at 10:28 PM
    COTundraRoamer
    Dustin
    Denver, CO
    18' Platinum CM
    Agreed, but it's not so much about the amperage as it is the voltage drop with lighter gauge wire @ 12v. My ARB fridge has a low voltage cutoff if power reads to low. At 30+ ft of wire it becomes a possibility of kicking in
  17. Jul 3, 2018 at 10:42 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Yes, I could see that being valid.
  18. Jul 4, 2018 at 4:23 AM
    ZPMAN
    Minnesota
