Added auxillary fuel tank
Discussion in '2nd Gen Tundras (2007-2013)' started by Marcian, Mar 6, 2021.
  1. Mar 6, 2021 at 9:00 AM
    Marcian
    Marcian [OP] Love Toyota
    Marcia
    Washington state
    07 tundra
    Leveling kit, air bags, trailer brakes, auxillary fuel tank,
    Added a fuel tank. But lost power to the fuse box under the dash that controls the radio, mirrors, acc, and cig lighter. Can't figure out why.
  2. Mar 6, 2021 at 9:06 AM
    ultrarunner
    ultrarunner New Member
    2013 Sequoia Platinum
    With so many components not powered, I'd check all the large connectors. And retrace the areas you were working at during the aux fuel tank install.
  3. Mar 7, 2021 at 6:25 AM
    supermotobobby
    supermotobobby New Member
    Bobby
    2022 Tundra Platinum 4x4
    Where did you mount the aux tank? Pictures?
  4. Mar 7, 2021 at 6:47 AM
    timsp8
    NY
    With the entire fuse box without power, sounds like something shorted out. Need more info on what you did to install the aux fuel tank. Any other changes/mods?
  5. Mar 8, 2021 at 8:43 PM
    Marcian
    Marcia
    Washington state
    07 tundra
    @supermotobobby the auxillary tank is in the bed. I'll post photos tomorrow
    @timsp8 the entire fuse box is not out, only 3 fuse ports at the dash panel are not getting power, cig, acc & radio. Found a relay that control those ports, changed it but they still do not work. ☹️
  6. Mar 8, 2021 at 8:56 PM
    Marcian
    Marcia
    Washington state
    07 tundra
    @timsp8 I'll post photos tomorrow. Auxillary tank is in the bed. Installed ball valve filter, selinoid valve, and fuel pump. Initially ran power for selinoid and fuel pump to a toggle switch then the acc fuse. I think switch was bad. Nothing worked. Replace toggle then got a fuse link and ran directly to the battery. Pump worked, getting gas The next day went to start truck, battery was dead. Jumped the truck drove it and realized radio wasnt working when I put the kid in the car and went to turn on the dvd for him.☹️
  7. Mar 9, 2021 at 11:18 AM
    Marcian
    Marcia
    Washington state
    07 tundra
    Toyota says it's a control module $1500
