Add vent
Discussion in '1st Gen Tundras (2000-2006)' started by Grn4x4, May 3, 2025 at 7:28 AM.
  1. May 3, 2025 at 7:28 AM
    Grn4x4
    Grn4x4 [OP] New Member
    Yesterday
    2000 tundra limited
    So I’ve been working on my new to me 2000 limited access cab, removed the front diff to install a spartan locker and replace the bad needle bearing with a bushing. Long story short everything was super grimy and crusty and I wound up breaking off the nipple to the add vent. Is it possible to drill it out and add a screw in vent or am I stuck buying a whole new setup. I really don’t want to spend 400+ on a new oem actuator. Are there any decent aftermarket options?
  2. May 3, 2025 at 7:35 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    The diff vent is 1/8 inch NPT thread. No reason you shouldn’t be able to drill it out and retap. Might also try just drilling the stuck part with a reverse bit. Just don’t break off an easy out
    G_unit3000 likes this.
  3. May 3, 2025 at 7:52 AM
    Grn4x4
    Yesterday
    2000 tundra limited
    It’s the plastic vent on the axle disconnect that broke, hopefully no danger of breaking anything other than the plastic that’s already messed up
