Add led running board lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jamesz, Jul 28, 2020.
  1. Jul 28, 2020 at 11:23 AM
    Jamesz
    Jamesz [OP] New Member
    Just got 2 60 inch strip of led ip67 3m adhesive stick ons. Plan to go on the frame so it lights up when i hit the clicker key fob. Going to run pass side under truck following factory wire to join driver side an come into the grommet driverside rear. I know these lights say it requires 12v. Can i tap into the cargo wire without blowing a fuse? That would make them turn on the way i said but i dk which wire that is. Everyone says its a gray thin wire. Im worried 120 inchs of led at 3.5 watt a foot is going to over power the cargo light fuse. It is going to be a total load of 35 watts. Think cargo light can handle that? This is rough estimate.... Thanks guys
  2. Jul 28, 2020 at 11:24 AM
    The color wire depends on the year of the Tundra.
  3. Jul 28, 2020 at 11:25 AM
    Jamesz
    Sorry 2015
  4. Jul 28, 2020 at 11:44 AM
    biebs96
    PA
    If you utilize the footwell light wires they will fade on and off when you lock/unlock.
    that’s what I did.
    https://youtu.be/Q5VmAUuNGnE
  5. Jul 28, 2020 at 12:14 PM
    Jamesz
    Ya thats what i need footwell light is what i need to tap into which color wire there is a whole lot and chances are ima mess up going by videos
