Add a leaf w/o pulling whole leaf pack out?
Discussion in 'Suspension' started by Tundra18overland, Oct 2, 2021.
  1. Oct 2, 2021 at 6:40 PM
    Tundra18overland
    Tundra18overland [OP] Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    Anyone know if it's possible to Add a leaf w/o pulling the whole leaf pack out?
    Please provide resources if you have them
  2. Oct 2, 2021 at 6:51 PM
    Sunnier
    Sunny
    San Diego, CA
    Uhhh, no. As far as I know, you’ll need to pull them off, stack in the add-a-leaf, and re-install. The leafs bear weight, so you’ll have to alleviate the weight to install the new leaf.
  3. Oct 2, 2021 at 6:53 PM
    Tundra18overland
    Jesse
    GA
    Thanks, I'll also need to pop out the old thru bolt and get a longer one, correct?
  4. Oct 2, 2021 at 7:49 PM
    Sunnier
    Sunny
    San Diego, CA
    Probably. And don’t reuse U-bolts.
  5. Oct 2, 2021 at 11:27 PM
    Yes. As @Sunnier said, do not reuse Ubolts. Toytec carries the center bolt and ubolts. The ubolts were around $40 for a full set of four.
  6. Jan 16, 2022 at 7:38 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    in theory you could add a leaf "with out pulling them all out" but it would be way more work and a weird working position as you would have to disassemble the whole back but leave the main leaf that bolts to the chassis and awkwardly hold every thing to put it all back together. way easier on a bench top and less work plus since your not having to use your 4th hand to hold stuff you can occasionally uses your 2nd hand for holding a beer. :D:cheers:
    crikeymike likes this.
