Actual tire sizes and weights
Discussion in 'General Tundra Discussion' started by canadianguy, Sep 20, 2019.
  1. Sep 20, 2019 at 10:22 AM
    canadianguy
    canadianguy [OP] New Member
    Kevin
    Lloydminster Alberta
    2017 SR5 trd off-road
    All the usual stuff!
    So after I installed my bilstein 6112 with a .5” coachbuilder shim on each side i stood back and looked at my once beefy 315/70r17 BFG ko2 Tire’s and realized how small they looked. I went inline looked at the specs, website says 34.4 tall 12.7 wide and 63lbs. Actual size mounted is 12” wide to the bulges (tread is 11”) height is 34.4” and weight is 66lbs. If I woulda know that the size and weights were out to lunch I woulda got different tires. Anyone else got different sizes and weights from what they thought they were getting?
  2. Sep 20, 2019 at 10:38 AM
    canadianguy
    Kevin
    No so much frustrated as just make the tires as big as you advertise lol and I will be getting bigger next time. Just think of this as info for ppl that wanna know proper sizes for their builds. Like I said if I woulda know I woulda went a different rout
  3. Sep 20, 2019 at 10:44 AM
    canadianguy
    Kevin
    Height was fine but width was the biggest thing I found, almost a inch (.7) narrower
    15Yota likes this.
