Access points from outside the cab to the inside
Discussion in '1st Gen Tundras (2000-2006)' started by SouthPaw, Nov 19, 2019.
  1. Nov 19, 2019 at 8:29 PM
    SouthPaw
    SouthPaw [OP] The headlight guy
    2000 Limited 4x4 AC
    Where are all the access points to get wires from outside the cab to the inside? I know there is one (maybe two) under the each side the front floor boards but are there any more? I am planning on putting an inverter under the drivers side seat and need to run some pretty thick cable from the battery to the inside the cab. I also want to possibly install a light bar which will require wires going to the inside of the cab.
    Are there any access points along the fire wall?
  2. Nov 19, 2019 at 8:32 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    There's a grommet on the firewall that the main wiring harness passes through in the driver's side at the front of the kick panel. There is enough room for a 4 ga cable for sure, typically used for installing amps and such.
  3. Nov 19, 2019 at 9:36 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    There's a grommet on each side of the firewall. There are 4 or 5 small grommets each side (inboard side of rocker) near where the OEM steps bolt up. There are a couple more beneath and aft of the front seats. There may be a couple more at the back of the cab between cab and bed.
    SouthPaw[OP] likes this.
  4. Nov 20, 2019 at 2:52 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Might want to consider running a small fuse box while your at it. That way you can run many interior accessories down the road without running more hot wires. That's my plan eventually. I was actually planning a fuse block and a relay block under my center console if I can get it to fit. My plan was to just use a cheaper amp wiring kit to power it. I was budgeting around $50-60 total for all the expansion space of interior 12v I can think of.
    Something like these.
    https://www.amazon.com/6-Way-Blade-LED-Indicator-Protection/dp/B00QMTAZ1W/
    https://www.amazon.com/ONLINE-LED-STORE-12-Slot-Installation/dp/B072KJNPHJ
    SouthPaw[OP], bmf4069 and tvpierce like this.
  5. Nov 20, 2019 at 5:27 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
  6. Nov 20, 2019 at 5:52 AM
    KarmaKannon
    Utah
    Some junk
  7. Nov 20, 2019 at 7:45 AM
    bsavoir
    bsavoir New Member
    Killeen, TX
    No, but it does allow for a more secure mounting IMO. The one you posted I have now for my 6 gang switch and I feel at some point it will break those 2 side mounting brackets. I was searching for a while to find this specific one, just thought I would put it out there so other can see. I'm going to do a similar setup you are now, I need some constant hot wire to power a few things when the truck is off and some active by the ACC/ON positions.
  8. Nov 20, 2019 at 9:22 AM
    SouthPaw
    2000 Limited 4x4 AC
    Excellent point! I ended ordering this one here because I plan on mounting it on the inside of the drivers fender. It also is waterproof and has a post for both positive and negative cables instead of having to ground each line.
    https://www.amazon.com/gp/product/B07HDZVW3P/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    This will make it alot easier if/when I decided to get my light bar on the front and cube lights on the rear bumper.
  9. Jan 15, 2023 at 10:07 AM
    Hawkeye2015
    Hawkeye2015 New Member
    2022 Lunar Rock Tundra TRD
    I found a small grommeted opening behind the battery on the passenger side of the engine compartment. It is located to the left and above a larger rubber boot that has a wiring harness running into the cab. What I am asking is this: I have tried to locate the point inside the cab where I can access this small opening, but am unable to actually find it. It appears to be higher than the one I use on the driver's side of the engine compartment. Has anyone used the one behind the battery and if so, might you be able to tell me how I find its access point inside the cab. I do not want to just push something through the opening that might interfere with any of the other wiring located inside that part of the dashboard. Thanks for any help.
