AC won’t blow air at all
Discussion in 'General Tundra Discussion' started by Erickstrd20, Dec 28, 2022.
  1. Dec 28, 2022 at 7:36 PM
    Erickstrd20
    Erickstrd20 [OP] New Member
    2020 white tundra TRD sport
    I have a 2020 tundra TRD sport. And recently when I turn on the AC/heater everything turns on fine on the controls but it wont blow no air whatsoever. It blows whenever it wants to. Has this happened to anyone? I checked some fuses but everything seems good. Any idea what it could be?
  2. Dec 28, 2022 at 9:09 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    It’s your blower motor. It takes less than 5 minutes to replace. It’s under the dash in the passenger footwell. 3 screws and a plug is all that holds it in. The factory one is such a pile of crap that I bought a knockoff on Amazon. It’s been working fine for a couple years now.
  3. Dec 29, 2022 at 3:38 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Still under warranty? I'd let Toyota do the repair if it is.
  4. Dec 29, 2022 at 4:52 AM
    Erickstrd20
    I’m going to have to look into that blower motor then. And no it’s not under warranty anymore 2020 with 58K miles
  5. Dec 29, 2022 at 6:19 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    Usually there is a resistor pack in blowers that controls speed. If that fails, it will only blow on high. If your automatic climate control system is changing the fan speed based on temp and settings, it may seem like the fan is possessed. Check out the resistor pack or perhaps get an exorcist....seriously, if you can get the fan in manual mode, try the different speeds.
  6. Dec 29, 2022 at 8:10 PM
    Erickstrd20
    Done! Switched out the blower motor took about 5/10 minutes and air is finally blowing again!
  7. Jan 4, 2023 at 10:03 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Did the aftermarket blower motor feel stronger than the factory one? I removed mine the other day as it was full of leaves ect. I took the cabin air filter out to allow the blower to move more air with less restrictions. Only downside is now debris can fall into the blower assembly.
    I was thinking about looking for a higher speed blower motor replacement.
  8. Jan 4, 2023 at 5:59 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Honestly, it “felt” stronger than the factory one, but mine had been dying for such a long time that I didn’t remember what it was supposed to feel like anymore.
  9. Jan 4, 2023 at 6:36 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I know the feeling, twice I have put a new battery in my old F150. Both times I’m instantly surprised how fast it cranks and starts. Those old batteries get sluggish and you get used to it.
  10. Jan 9, 2023 at 2:13 PM
    Alabamasky53
    Alabamasky53 New Member
    Hey all, I’ve been reading through these because I have a similar issue on my 2018 Toyota sequoia TRD sport. Blower motor sounded horrible like a failing barring. Swapped it out with an aftermarket 4 seasons and there is no air what do ever. controls still powered but nothing blowing on any setting… this model does not have interior cabin fuses for the AC system. Just 1 40 amp in the engine compartment. All dealers and story’s online parts I look at they don’t have resistors for the front, just the rear auxiliary motor. Do you think this could be a relay issue? If so can you tell me wich one to look for because the fuse box lid has nothing marked for A/C.. I need some help please lol
  11. Jan 9, 2023 at 2:49 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    For some reason I just had the image in my head of you swerving all over the road because you were getting pelted by several bees being spit out of your vents at a high rate of speed. :burnrubber:
  12. Jan 9, 2023 at 2:56 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Would you mind posting a link to the Blower Motor you purchased?
  13. Jan 9, 2023 at 3:41 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    What year?
    Truck has a dedicated blower motor fuse 50A HTR. The green wire is the signal for speed from the AC amplifier. Blower motor circuit is pretty simple really.
