AC or Heat always on recirculate at start up ?
Discussion in 'General Tundra Discussion' started by Scpringle, Jun 24, 2017.
  1. Jun 24, 2017 at 3:51 PM
    Scpringle
    Scpringle [OP] New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    I have 2015 DC(manual AC controls ) and every time I start up its in recirculate . This is with heat or AC and not set to MAX . Is this normal ? It also takes a few seconds for the fan to kick up to hi setting ?
    thanks in advance !
  2. Jun 24, 2017 at 7:46 PM
    FLTrucks
    FLTrucks New Member
    Did the fan just start acting up to where it would take a while for the fan to get to high? Your ac ecu may be going bad or try amd drop the blower motor in the hvac and clean it. I think the recirculation button is awlays on when you start your truck.
    DalTee likes this.
  3. Jun 24, 2017 at 8:02 PM
    Scpringle
    Jackson MS
    @FLTrucks No the fan has always been slow , it is just not instant HI when you crank it . it gradually goes to high in a reasonable time . It may just be me coming from my 4Runner . Thanks again
  4. Jun 24, 2017 at 8:23 PM
    FLTrucks
    FLTrucks New Member
    Maybe. I Just never really noticed it. I know with my auto ac it will gradually go up to high.
    Scpringle[OP] likes this.
  5. Jun 24, 2017 at 11:29 PM
    Midnighttaco08
    Midnighttaco08 High Quality H2O Inspector
    Sam
    Gilbert, AZ
    2017 Quicksand TRD OR 4x4 2008 Indigo Ink Tacoma TRDOR
    None yet!
    Mine does both. It also defaults to recirc when I turn the ac on via the button. (Max ac is always forced recirc for max cooling)
    At first thought the delayed hi was a glitch, but a friends does it as well.
  6. Jun 25, 2017 at 3:02 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    My fan ramps up also but I thought it was because I have a Limited with a digital temp set, the recirc is designed to be on at outside temps over 75 but that doesn't explain the heat.
  7. Jun 25, 2017 at 4:05 AM
    PermaFrostTRD
    Northern NY
    Try adjusting the temp dial at least one or more clicks away from the "max ac" setting. Max ac will always default to engage the recirculating function.
    Scpringle[OP] and MT Madman like this.
