AC GOING OUT, HELP!!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sharla001, Aug 18, 2024.
  1. Aug 18, 2024 at 1:41 PM
    Sharla001
    Sharla001 [OP] New Member
    Tony
    2014 Thunder
    None
    So my AC is not working half the time. It will not turn on, then after all day at work it will come on heading home.
    Turn the AC to on position light will come on, however nothing happens. Had battery checked, it’s at 100 %. any suggestions? How do I check the compressor?
    I’m in Dallas, Tx and it’s H O T!!
    Thank you for your help
  2. Aug 18, 2024 at 7:25 PM
    VUDUBLU
    VUDUBLU New Member
    David
    2019 TRD PRO Tundra
    Ready lift 2 inch lift with 295’s
    Do you hear your blower motor turn on? The one under the glove box?
    My AC blower motor started to go out, but unlike your situation, my AC was still turning on, but it was making an annoying noise. Did you notice any noise prior or leading up to AC going out?
    ZappBrannigan likes this.
  3. Aug 18, 2024 at 7:35 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Look at the compressor with the ac on and see if the clutch is turning
  4. Aug 18, 2024 at 7:58 PM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    I'd start with the simple thing first; the ac compressor and blower motor relays. They can be intermittent like that if going bad. You might have a spare on the block somewhere already or you can swap them around temporarily to see if that fixes things, then you'd know you need a new one. OEM Denso ones are stupid expensive but you can get decent aftermarket ones for $10-15.
  5. Aug 19, 2024 at 6:19 AM
    Sharla001
    Tony
    2014 Thunder
    None
    Yes it has been making noise. It looks like the pulley is turning.
    And the blower sometimes comes on
