AC Duct Leak
Discussion in '1st Gen Tundras (2000-2006)' started by GuiltySpark, Oct 18, 2024.
  1. Oct 18, 2024 at 7:44 PM
    GuiltySpark
    GuiltySpark [OP] New Member
    East Coast
    2003 Grey Tundra Limited Access Cab
    LED Interior lights Pioneer Touchscreen Radio w/ CarPlay LED Dashboard Lights LED 3rd brake light assembly Rack and Pinion polyurethane bushings upgrade.
    I've had this problem since I've had this truck, where I get air blowing out of the ducts all the time, regardless of what setting the selector switch is on. Granted, I can still switch between the settings, and it will change the intensity of how much air blows from the duct locations that are "not selected".
    Has anyone else encountered this issue? Would it be as simple as replacing something behind the climate control panel?
  2. Oct 19, 2024 at 4:56 AM
    shifty` I'm having daydreams about night things
    It happens to blow even when recirculate button is turned on but the position is off?
    Are you 100% sure you have all four unique speeds, also? Or do the 3rd and 4th position happen to be the same. Like your climate control cables maybe jumped, shifting the speed positions one over?
  3. Oct 19, 2024 at 5:04 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Sounds like your blend door actuator is malfunctioning.
