AC defaults to recirc
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stumpjumper, Aug 4, 2020.
  1. Aug 4, 2020 at 12:28 PM
    Stumpjumper
    Stumpjumper [OP] Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Can you change this in the settings? My Tacomas did not do this. Whenever i turn the AC on for the first time after starting it goes to recirc. I rarely use recirc.
  2. Aug 4, 2020 at 12:29 PM
    Sunnier
    Sunny
    San Diego, CA
    Does it do this all the time, or just when you have it on the max setting?
  3. Aug 4, 2020 at 12:30 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    May sound silly but make sure your temperature knob isn't turned fully to the "max" setting because that automatically makes it go to recirc. Turn it clockwise just a tad and it should kick off
    BravoDeltaRomeo likes this.
  4. Aug 4, 2020 at 12:40 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I know about the max setting and it is not on max
  5. Aug 4, 2020 at 12:42 PM
    Sunnier
    Sunny
    San Diego, CA
    Ok. Then something may be operating incorrectly on yours. My 2017 only does what you’re describing on the max setting.
  6. Aug 4, 2020 at 12:43 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    Just offering the simplest solution first. Don't know how much general automotive knowledge you have.
  7. Aug 4, 2020 at 12:50 PM
    Critical05
    Critical05 New Member
    2018 MGM TRD Sport, Crewmax 4x4
    Normal, mine does this every time. Nothing you can do but push the button to turn it off.
    Cpl_Punishment and JimboSlice413 like this.
  8. Aug 4, 2020 at 12:55 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Maybe a mid year 2017 change since Sunnier has a 2017 that does not do it
  9. Aug 4, 2020 at 1:03 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I had this originally turned off and didn't realize one could toggle it...I downloaded the free app Car Scanner and it allows it to be an "auto-on" feature or turned off where you must select the climate recirc function yourself...I NOW have it on automatically when I hit AC...bonus feature, you can also toggle off your seat-belt chimes for both driver and passenger seats (and rear if you have them)...I purchased the app for $3.99...a mere drop in the bucket...
    Sunnier and Black Wolf like this.
  10. Aug 4, 2020 at 1:16 PM
    :thumbsup:
    HulkSmurf14[QUOTED] likes this.
  11. Aug 4, 2020 at 1:36 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    So a FREE app cost $3.99?
  12. Aug 4, 2020 at 1:37 PM
    HulkSmurf14
    2014 Tundra Limited
    Simmer down...you can use it freely and cost you nothing but it doesn't unlock "additional features" without purchasing the app...costs less than 2 gallons of fuel...you got this!
    JimboSlice413 likes this.
  13. Aug 4, 2020 at 1:43 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Your post is not clear. I dont care about $4. So to clarify. If you want to change settings you pay the $4. If you just want to display stuff it is free?
  14. Aug 4, 2020 at 1:46 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    Thats pretty cool. I wonder if there's an option to turn the seat heaters back to off when i turn the car off. Often my wife has the seat heater on in the passenger seat and it gets left on with noone in it because the tundra never turns it off even after restarting the truck
  15. Aug 4, 2020 at 1:52 PM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    I have a 2014 and it does this. I did see the setting in Techstream, but forgot to turn it off. It is configurable with other software like Carly too.
  16. Aug 4, 2020 at 2:08 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Wish that worked for me. Goes to recirc every time I start the truck no matter what
    Cpl_Punishment likes this.
  17. Aug 4, 2020 at 2:21 PM
    HulkSmurf14
    2014 Tundra Limited
    No worries and I apologize for not being clear...you're right...and I suppose my wife is also mostly right :p
    You an turn off only the driver's seat-belt chime in the free mode as well as view most of the PIDs, however, you get more PIDs released and other options you can toggle with the purchased version...I hope that helps some...
    Sunnier likes this.
  18. Aug 4, 2020 at 2:36 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Do you have the Carly? I was interested in that also but wanted to get more info /feedback.
  19. Aug 4, 2020 at 2:39 PM
    Snaz
    Snaz I <3 explosions
    SE CO
    '20 Limited Quicksand
    My '20 does it everytime you start it up.
  20. Aug 4, 2020 at 2:54 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I assume that is if fan is on. I normally turn my fan off when i shut off truck.
  21. Aug 4, 2020 at 2:58 PM
    Snaz
    SE CO
    That I don't know. Hot here atm, I've had it of recirc and turned it on and off, but I've never had the fan off auto.
  22. Aug 4, 2020 at 3:05 PM
    sf319
    sf319 New Member
    Utah
    I have tried it but didn't purchase it since I have access to Techstream. It has a lot of settings that can be changed.
  23. Aug 4, 2020 at 3:44 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Which ELM 327 do have and cost
  24. Aug 4, 2020 at 4:02 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    What does your A/C controls look like? If you have it on auto it will always default to recirc as that's the fastest easiest way to cool the vehicle.
    Also, just out of curiosity why don't you like using the recirc function?
  25. Aug 4, 2020 at 4:31 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I thought I had mine "trained" to remember that I don't want recirc on but it seems to have "forgotten" and I'm back to hitting the button every time I turn on the A/C for the first time while driving. Doesn't do it if I turn the A/C on and off multiple times in the same trip.
  26. Aug 4, 2020 at 5:31 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I just prefer fresh air unless i am on a dusty road. Also i have heard of people getting moldy filters in humid conditions when they always run recirc.
    Medic343[QUOTED] likes this.
  27. Aug 4, 2020 at 5:37 PM
    PermaFrostTRD
    Northern NY
    Even if you’re not on “max” on the temp dial, it will crank on the recirc to help cool faster. Mine does this when the ambient temp is higher. Simple button click solves it.
  28. Aug 4, 2020 at 5:59 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    I disagree with you...I live in the desert and the ambient temperature is always higher and my '17 will not go on recirc unless I push the button or turn the dial to max
  29. Aug 4, 2020 at 6:30 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    It is annoying because no other vehicle has done this and i prefer fresh air
    Cpl_Punishment and Medic343 like this.
  30. Aug 4, 2020 at 6:34 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    I can definitely see that...I live in the desert so it's always hotter than heck and dusty so recirc is my preference. Luckily no humidity here either
