AC compressor clutch spin stop spin stop spin stop and so on.
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by JayKay, May 20, 2025 at 4:09 PM.
  1. May 20, 2025 at 4:09 PM
    JayKay
    JayKay [OP] New Member
    Does anyone know why my AC compressor clutch spin stop spin stop spin stop and so on when the AC is on? I have a 2014 Tundra Platinum and I've already changed the relay because of the blinking AC light but that didn't fix the problem. I also bought a new Denso AC compressor but didn't install it yet. Just want to see if it's anything else causing this spin stop problem before i replace the compressor. The clutch also doesn't go in when the AC is on and working. While the AC is working and blowing cold air, the clutch keeps spinning and stopping like every 5 seconds.
  2. May 20, 2025 at 5:19 PM
    JayKay
    And I just read that it might be low on freon which will cause the AC compressor clutch to not spin. But the truck is blowing really cold air so I'm not sure what's going on until I check the freon pressure.
  3. May 20, 2025 at 5:39 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Did your battery recently die? Or did you replace it. If so, its probably normal.
